[petsc-users] MPI bindings for PETSc local and global numbering
Jed Brown jed at jedbrown.org
Mon May 11 16:07:51 CDT 2015
Justin Chang <jychang48 at gmail.com> writes:
> ${MPIEXEC}.hydra -n <procs> -bind-to hwthread -map-by socket ./myprogram
> <args>
Why are you using "-map-by socket" if you want a sequential ordering?
Abstractly, I expect a tradeoff between load balancing in case of
correlated irregularity and cache locality, but would tend to prefer
sequential ordering (so that nearby row numbers are more likely to share
cache).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150511/3aa48940/attachment.pgp>
