[petsc-users] configure error on Titan with Intel
Satish Balay
balay at mcs.anl.gov
Fri May 8 14:17:36 CDT 2015
Executing: cc -c -o /tmp/petsc-8S0Qxp/config.setCompilers/conftest.o -I/tmp/petsc-8S0Qxp/config.setCompilers /tmp/petsc-8S0Qxp/config.setCompilers/conftest.c
<snip>
Executing: cc -o /tmp/petsc-8S0Qxp/config.setCompilers/conftest /tmp/petsc-8S0Qxp/config.setCompilers/conftest.o -lstdc++
Executing: /tmp/petsc-8S0Qxp/config.setCompilers/conftest
ERROR while running executable: Could not execute "/tmp/petsc-8S0Qxp/config.setCompilers/conftest":
Hm - there is no error message [or error number] listed.
Perhaps you can try debugging this without PETSc. i.e compile/run a
simple code and see if it works.
You can use src/benchmarks/sizeof.c or
http://trac.mpich.org/projects/mpich/export/60482cc2ca9a740d049444a9261a04a3007bc306/examples/cpi.c
[perhaps runs from $HOME work - but not /tmp ? - but then you said -
'This workflow seemed to work for pgi & gnu programming envs' - so
this shouldn't be the problem]
Satish
On Fri, 8 May 2015, Mark Adams wrote:
> I added the LD path stuff and that seems to have fixed this problem ... but
> there are still problems.
> On Fri, May 8, 2015 at 1:23 PM, David Trebotich <dptrebotich at lbl.gov> wrote:
> > This has all come up because I cannot build Chombo-crunch using gnu
> > prgenv---cannot find mkl anymore. So olcf consultants advised Intel
> > prgenv. I am not sure yet what form of libs are used, that is mkl, blas, I
> > don't know.
> > David Trebotich
> > sent from mobile
> > (510) 384-6868
> > On May 8, 2015 9:22 AM, "Satish Balay" <balay at mcs.anl.gov> wrote:
> >> On Fri, 8 May 2015, Ed D'Azevedo wrote:
> >> > Is petsc using ACML specific routines?
> >> > If not, perhaps MKL provides the lapack/blas and ACML is not needed?
> >> > Just a thought.
> >> yup PETSc can use whatever blas/lapck user provides.
> >> In this case PETSc was not seeking acml - but the 'module' env was
> >> presumably setup with acml [and the compilers are attempting to use
> >> these modules directly - irrespective of PETSc]
> >> Satish
