[petsc-users] Obtaining bytes per second
Justin Chang
jychang48 at gmail.com
Thu May 7 09:23:30 CDT 2015
So to summarize, if I understand everything, I should do the following:
1) calculate the flop/byte ratio for various problem sizes and solver
methods on one process and:
a) use the ratio to estimate the ideal flops/s based on the stream bw.
Compare this to the measured flops/s from my Petsc program?
b) show the associated wall-clock times.
c) warn that this model is uncached and merely gives a rough estimate of
the performance.
2) Do a strong-scaling/speed up study to illustrate how these problems
scale across multiple processes. Optionally see what the optimal number of
processes is required for various problem sizes and solvers.
Am I missing anything?
Justin
On Thursday, May 7, 2015, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, May 7, 2015 at 8:35 AM, Jed Brown <jed at jedbrown.org> wrote:
>> Matthew Knepley <knepley at gmail.com> writes:
>> > I think it would be much more interesting, and no more work to
>> > a) Model the flop/byte \beta ratio simply
>> > b) Report how close you get to the max performance given \beta on your
>> > machine
>> This is also easily gamed; just use high-memory data structures, extra
>> STREAM copies, etc.
> I completely agree that all the performance measures can be gamed, which
> is why
> its important to always show time to solution as well.
> Matt
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150507/08fc4855/attachment.html>
