[petsc-users] Obtaining bytes per second
Jed Brown jed at jedbrown.org
Wed May 6 08:29:13 CDT 2015
Matthew Knepley <knepley at gmail.com> writes:
> I think the idea is to be explicit. I would just use something like
>   # Vecs * Vec size * 8 bytes/double + <same for Mat>
> and forget about small stuff. This model is uncached,
This is for a perfect cache model -- each byte of the data structures
needs to be fetched from DRAM only once.
Make sure that "# Vecs" actually means the number that are accessed.
For example, GMRES accesses an increasing number of vectors on each
iteration (until a restart).
> and you just state that up front. Someone else can take the data and
> produce a more nuanced model.
> You can use the Flop counts (not Flop/s) from PETSc,  and get a rough
> estimate
> of flop/byte ratio.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150506/038a9036/attachment.pgp>
