[petsc-users] Global matrix from global sub-matrices
Bikash Kanungo
bikash at umich.edu
Tue May 5 16:45:48 CDT 2015
Thank you guys for the prompt replies.
I have never used DMs so far in my research. On a cursory glance
MatCreateNest seems to be simpler. But I would like to dig into
MatGelLocalSubmatrix to see if it provides any advantage.
Bikash
On Tue, May 5, 2015 at 3:34 PM, Bikash Kanungo <bikash at umich.edu> wrote:
> Hi,
> I have four global matrices: A (mxm), B (mxn), C (nxm) and D (nxn). All of
> these are of type MATMPIAIJ (sparse parallel matrix) created using number
> of global rows and columns. I want to construct an (m+n)x(m+n) global
> matrix called M which would have A, B, C and D as its sub-matrices in
> clockwise fashion starting from A at the upper-left. What can be the best
> way to construct M from A, B, C and D sub-matrices?
There are at least two ways:
1) Use
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetLocalSubMatrix.html
to get a view
into the matrix for each submatrix A, B, C, D
2) Use
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateNest.html
Matt
> Thanks,
> Bikash
> Bikash S. Kanungo
> PhD Student
> Computational Materials Physics Group
> Mechanical Engineering
> University of Michigan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150505/ced4729c/attachment.html>
