[petsc-users] Load real matrix in complex PETSc build.
stefano.pedraglio at libero.it
Mon May 4 14:34:34 CDT 2015
Hallo
I have saved a large matrix using PETSc configured with scalar type real and I used binary viewer. I need now to compute the eigensolutions in another program using SLEPc and I need to use a complex shift. I have configured and compiled another PETSc and SLEPc build for complex scalars. I know it is not possible to load a matrix saved as real when using a program configured for complex numbers. Is there a workaround to perform this operation? Maybe saving and loading in some other format the matrix or using a different library for eigenvalue computation. Thank you for any suggestion.
Hallo
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150504/fe299bba/attachment.html>
