[petsc-users] Matrix Assembly too slow
Vijay Gopal Chilkuri vijay.gopal.c at gmail.com
Sat May 2 15:49:51 CDT 2015
Ok so here goes.
I've attached a tarball with a directory which contains the required files
to compile *ex1.c *
The UNIT_L1_ subroutine generates the nonzero elements of my hamiltonian
given a row, it is contained in the
irpf90.a library. The actual fortran code is quite ugly.
Please tell me if you are able to compile and run the codes.
Thanks a lot,
 Vijay
On Sat, May 2, 2015 at 10:26 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On May 2, 2015, at 2:57 PM, Vijay Gopal Chilkuri <
> vijay.gopal.c at gmail.com> wrote:
> > Please let me clarify,
> > @Matt:
> > I've followed the proper manner to rapid assembly.
> > That is :
> >   1. preallocation
> >   2. nonzero ownership
> > Despite of having done the proper preallocation (as you can see from the
> output file),
> > the matrix takes ages to assemble, whereas the same code works for a
> larger matrix with (100,000,000) elements taking 2 min to assemble !
> > @Barry:
> > I am not touching any file in the code that I attachd.
> > What i'm doing is that each processor will (according to it's ownership
> range) get it's nonzero entries
> > using a Fortran subroutine (UNIT_L1_) and call MatSetValues() for their
> respective rows.
> > Again to be clear I"m NOT doing file I/O anywhere.
>   Oh sorry, where is the fortran code? I assumed the fortran code was
> reading from a file.
>    Based on what you sent yes it should take little time; if you send
> something I could run I could try to see why it would be slow.
>   Barry
> > Could you please have a look at the files attached.
> > On Sat, May 2, 2015 at 9:42 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   You have two hundred processes banging on the same file on the same
> filesystem fighting with each other to read in the matrix. That's like
> hiring two hundred guys to dig a ditch but making them share one shovel;
> you won't get speed up, you'll get speed down.
> >   Make a simple sequential PETSc program that reads in the matrix and
> then store it with MatView() in binary format. Then in your parallel
> program use MatLoad() to read the matrix in (it will take a few seconds to
> read in the matrix in that case).
> >   Barry
> > > On May 2, 2015, at 2:10 PM, Vijay Gopal Chilkuri <
> > > Hi,
> > > I'm trying to diagonalize large matrices using PETSc and SLEPc.
> > > I've successfully diagonalized 100 million dimensional matrix in
> 2hours.
> > > But, the problem is when i try to diagonailze (similar) a smaller
> metrix of
> > > dimension 67,000,000 (24 nonzero elements per row) with 10 noes
> running 20 processors each (similar to the 100 million case), the matrix
> assembly itself
> > > takes 2h !
> > > Could someone point out the mistakes that i'm making ?
> > > i attach the source code and the output with the mail.
> > > thanks,
> > >  Vijay
> > > #include <slepceps.h>
> > > #include <petsctime.h>
> > > #undef __FUNCT__
> > > #define __FUNCT__ "main"
> > > int main(int argc,char **argv)
> > >   Mat            A;           /* problem matrix */
> > >   EPS            eps;         /* eigenproblem solver context */
> > >   EPSType        type;
> > >   PetscReal      error,tol,re,im;
> > >   PetscScalar    kr,ki,value[52];
> > >   Vec            xr,xi;
> > >   PetscInt
>  n=16224936,ii,i,veclen,j,Istart,Iend,col[52],nev,maxit,its,nconv,countcol;
> > >   PetscInt       d_nz,o_nz;
> > >   PetscLogDouble t1,t2,tt1,tt2;
> > >   PetscBool      FirstBlock=PETSC_FALSE,LastBlock=PETSC_FALSE;
> > >   PetscErrorCode ierr;
> > >   PetscScalar    eigr;
> > >   PetscScalar    eigi;
> > >   PetscScalar    * data;
> > >   Vec          Vr,Vi;
> > >   char           filename[PETSC_MAX_PATH_LEN]="FIL666";
> > >   PetscViewer    viewer;
> > >   PetscBool      ishermitian;
> > >   int            mpiid;
> > >   long int            kk,iii;
> > >   long int            tcountcol,tcol[52];
> > >   float          val[52];
> > >   long int            ntrou=1;
> > >   long int            l1[52]={1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 1, 2,
> 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22,
> 23, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0       };
> > >   long int            l2[52]={2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 24,
> 23, 22, 21, 20, 19, 18, 17, 16, 15, 14, 13, 14, 15, 16, 17, 18, 19, 20, 21,
> 22, 23, 24, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0       };
> > >   long int          ktyp[52]={1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2,
> 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 0, 0, 0, 0,
> > >   double           xjjz[52]  ={0.0333333333333,-0.8, 0.,
> > >       0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
> > >   double           xjjxy[52] ={0.0333333333333,-0.8,0.,
> > >   double           xtt[52]   ={-1.0,0.,0.,
> > >   SlepcInitialize(&argc,&argv,(char*)0,NULL);
> > >   ierr = PetscPrintf(PETSC_COMM_WORLD,"\n1-D t-J Eigenproblem,
> n=%D\n\n",n);CHKERRQ(ierr);
> > >   ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
> > > //ierr = MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,n,n);CHKERRQ(ierr);
> > >   ierr =
> MatCreateAIJ(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,n,n,46,NULL,46,NULL,&A);CHKERRQ(ierr);
> > >   ierr = MatSetFromOptions(A);CHKERRQ(ierr);
> > >   ierr = MatSetUp(A);CHKERRQ(ierr);
> > >   ierr = MatGetOwnershipRange(A,&Istart,&Iend);CHKERRQ(ierr);
> > >   ierr =
> MatCreateAIJ(PETSC_COMM_WORLD,Iend-Istart,Iend-Istart,n,n,46,NULL,46,NULL,&A);CHKERRQ(ierr);
> > >   MPI_Comm_rank(MPI_COMM_WORLD,&mpiid);
> > >   ierr = PetscTime(&tt1);CHKERRQ(ierr);
> > >   for (i=Istart; i<Iend; i++) {
> > >       tcountcol=0;
> > >       iii=i+1;
> > >       if(i%5 == 0 && mpiid==0){
> > >         ierr = PetscTime(&t1);CHKERRQ(ierr);
> > >       unit_l1_(
> > >             l1,
> > >             l2,
> > >             ktyp,
> > >             &iii,
> > >             xjjxy,
> > >             xjjz ,
> > >             xtt  ,
> > >             &tcountcol,
> > >             &ntrou,
> > >             tcol,
> > >             val);
> > >       for(kk=0;kk<52;kk++){
> > >           value[kk] = val[kk];
> > >           col[kk] = tcol[kk]-1;
> > >         ierr = PetscTime(&t2);CHKERRQ(ierr);
> > >         ierr = PetscPrintf(PETSC_COMM_WORLD," i: %d\n mpiid: %d\ntime:
> %f\n",i,mpiid,t2-t1);CHKERRQ(ierr);
> > >       countcol=tcountcol;
> > >     ierr =
> MatSetValues(A,1,&i,countcol,col,value,INSERT_VALUES);CHKERRQ(ierr);
> > >         ierr = PetscPrintf(PETSC_COMM_WORLD," processor \n mpiid:
> %d\ntime: %f\n",mpiid,t2-t1);CHKERRQ(ierr);
> > >   ierr = PetscTime(&tt2);CHKERRQ(ierr);
> > >   ierr = PetscPrintf(PETSC_COMM_WORLD," Time used to build the matrix:
> %f\n",tt2-tt1);CHKERRQ(ierr);
> > >   ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> > >   ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> > >   ierr = PetscPrintf(PETSC_COMM_WORLD," Time used to assemble the
> matrix: %f\n",tt2-tt1);CHKERRQ(ierr);
> > >   ierr = MatGetVecs(A,NULL,&xr);CHKERRQ(ierr);
> > >   ierr = MatGetVecs(A,NULL,&xi);CHKERRQ(ierr);
> > >   ierr = EPSCreate(PETSC_COMM_WORLD,&eps);CHKERRQ(ierr);
> > >   ierr = EPSSetOperators(eps,A,NULL);CHKERRQ(ierr);
> > >   ierr = EPSSetProblemType(eps,EPS_HEP);CHKERRQ(ierr);
> > >   ierr = EPSSetWhichEigenpairs(eps,EPS_SMALLEST_REAL);CHKERRQ(ierr);
> > >   ierr = EPSSetFromOptions(eps);CHKERRQ(ierr);
> > >   tol = 1.e-8;
> > >   maxit = 10000000;
> > >   ierr = EPSSetTolerances(eps,tol,maxit);CHKERRQ(ierr);
> > >   ierr = EPSSolve(eps);CHKERRQ(ierr);
> > >   ierr = PetscPrintf(PETSC_COMM_WORLD," Time used:
> %f\n",t2-t1);CHKERRQ(ierr);
> > >   ierr = EPSGetIterationNumber(eps,&its);CHKERRQ(ierr);
> > >   ierr = PetscPrintf(PETSC_COMM_WORLD," Number of iterations of the
> method: %D\n",its);CHKERRQ(ierr);
> > >   ierr = EPSGetType(eps,&type);CHKERRQ(ierr);
> > >   ierr = PetscPrintf(PETSC_COMM_WORLD," Solution method:
> %s\n\n",type);CHKERRQ(ierr);
> > >   ierr = EPSGetDimensions(eps,&nev,NULL,NULL);CHKERRQ(ierr);
> > >   ierr = PetscPrintf(PETSC_COMM_WORLD," Number of requested
> eigenvalues: %D\n",nev);CHKERRQ(ierr);
> > >   ierr = EPSGetTolerances(eps,&tol,&maxit);CHKERRQ(ierr);
> > >   ierr = PetscPrintf(PETSC_COMM_WORLD," Stopping condition: tol=%.4g,
> maxit=%D\n",(double)tol,maxit);CHKERRQ(ierr);
> > >   ierr = EPSGetConverged(eps,&nconv);CHKERRQ(ierr);
> > >   ierr = EPSPrintSolution(eps,NULL);CHKERRQ(ierr);
> > >   if (nconv>0) {
> > >     PetscViewerASCIIOpen(PETSC_COMM_WORLD,filename,&viewer);
> > >     EPSIsHermitian(eps,&ishermitian);
> > >     for (i=0;i<nconv;i++) {
> > >       EPSGetEigenvector(eps,i,xr,xi);
> > >       VecView(xr,viewer);
> > > #if !defined(PETSC_USE_COMPLEX)
> > >       if (!ishermitian) { VecView(xi,viewer); }
> > > #endif
> > >     PetscViewerDestroy(&viewer);
> > >   ierr = EPSDestroy(&eps);CHKERRQ(ierr);
> > >   ierr = MatDestroy(&A);CHKERRQ(ierr);
> > >   ierr = VecDestroy(&xr);CHKERRQ(ierr);
> > >   ierr = VecDestroy(&xi);CHKERRQ(ierr);
> > >   ierr = SlepcFinalize();
> > >   return 0;
> > > OUTPUT:
> > >  Time used to build the matrix: 1914.729022
> > > [0] MatStashScatterBegin_Private(): No of messages: 0
> > > [0] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [6] MatStashScatterBegin_Private(): No of messages: 0
> > > [6] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [182] MatStashScatterBegin_Private(): No of messages: 0
> > > [182] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [100] MatStashScatterBegin_Private(): No of messages: 0
> > > [100] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [60] MatStashScatterBegin_Private(): No of messages: 0
> > > [60] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [140] MatStashScatterBegin_Private(): No of messages: 0
> > > [140] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [120] MatStashScatterBegin_Private(): No of messages: 0
> > > [120] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [162] MatStashScatterBegin_Private(): No of messages: 0
> > > [162] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [20] MatStashScatterBegin_Private(): No of messages: 0
> > > [20] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [80] MatStashScatterBegin_Private(): No of messages: 0
> > > [80] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [40] MatStashScatterBegin_Private(): No of messages: 0
> > > [40] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [7] MatStashScatterBegin_Private(): No of messages: 0
> > > [7] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [185] MatStashScatterBegin_Private(): No of messages: 0
> > > [185] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [101] MatStashScatterBegin_Private(): No of messages: 0
> > > [101] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [61] MatStashScatterBegin_Private(): No of messages: 0
> > > [61] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [142] MatStashScatterBegin_Private(): No of messages: 0
> > > [142] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [130] MatStashScatterBegin_Private(): No of messages: 0
> > > [130] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [166] MatStashScatterBegin_Private(): No of messages: 0
> > > [166] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [21] MatStashScatterBegin_Private(): No of messages: 0
> > > [21] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [81] MatStashScatterBegin_Private(): No of messages: 0
> > > [81] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [44] MatStashScatterBegin_Private(): No of messages: 0
> > > [44] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [9] MatStashScatterBegin_Private(): No of messages: 0
> > > [9] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [187] MatStashScatterBegin_Private(): No of messages: 0
> > > [187] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [105] MatStashScatterBegin_Private(): No of messages: 0
> > > [105] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [62] MatStashScatterBegin_Private(): No of messages: 0
> > > [62] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [143] MatStashScatterBegin_Private(): No of messages: 0
> > > [143] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [132] MatStashScatterBegin_Private(): No of messages: 0
> > > [132] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [169] MatStashScatterBegin_Private(): No of messages: 0
> > > [169] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [24] MatStashScatterBegin_Private(): No of messages: 0
> > > [24] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [84] MatStashScatterBegin_Private(): No of messages: 0
> > > [84] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [45] MatStashScatterBegin_Private(): No of messages: 0
> > > [45] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [10] MatStashScatterBegin_Private(): No of messages: 0
> > > [10] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [188] MatStashScatterBegin_Private(): No of messages: 0
> > > [188] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [109] MatStashScatterBegin_Private(): No of messages: 0
> > > [109] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [63] MatStashScatterBegin_Private(): No of messages: 0
> > > [63] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [148] MatStashScatterBegin_Private(): No of messages: 0
> > > [148] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [133] MatStashScatterBegin_Private(): No of messages: 0
> > > [133] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [170] MatStashScatterBegin_Private(): No of messages: 0
> > > [170] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [25] MatStashScatterBegin_Private(): No of messages: 0
> > > [25] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [86] MatStashScatterBegin_Private(): No of messages: 0
> > > [86] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [47] MatStashScatterBegin_Private(): No of messages: 0
> > > [47] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [11] MatStashScatterBegin_Private(): No of messages: 0
> > > [11] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [190] MatStashScatterBegin_Private(): No of messages: 0
> > > [190] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [111] MatStashScatterBegin_Private(): No of messages: 0
> > > [111] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [64] MatStashScatterBegin_Private(): No of messages: 0
> > > [64] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [156] MatStashScatterBegin_Private(): No of messages: 0
> > > [156] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [134] MatStashScatterBegin_Private(): No of messages: 0
> > > [134] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [171] MatStashScatterBegin_Private(): No of messages: 0
> > > [171] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [26] MatStashScatterBegin_Private(): No of messages: 0
> > > [26] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [91] MatStashScatterBegin_Private(): No of messages: 0
> > > [91] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [48] MatStashScatterBegin_Private(): No of messages: 0
> > > [48] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [12] MatStashScatterBegin_Private(): No of messages: 0
> > > [12] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [192] MatStashScatterBegin_Private(): No of messages: 0
> > > [192] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [112] MatStashScatterBegin_Private(): No of messages: 0
> > > [112] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [65] MatStashScatterBegin_Private(): No of messages: 0
> > > [65] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [157] MatStashScatterBegin_Private(): No of messages: 0
> > > [157] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [135] MatStashScatterBegin_Private(): No of messages: 0
> > > [135] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [174] MatStashScatterBegin_Private(): No of messages: 0
> > > [174] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [28] MatStashScatterBegin_Private(): No of messages: 0
> > > [28] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [13] MatStashScatterBegin_Private(): No of messages: 0
> > > [13] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [194] MatStashScatterBegin_Private(): No of messages: 0
> > > [194] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [113] MatStashScatterBegin_Private(): No of messages: 0
> > > [113] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [66] MatStashScatterBegin_Private(): No of messages: 0
> > > [66] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [158] MatStashScatterBegin_Private(): No of messages: 0
> > > [158] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [136] MatStashScatterBegin_Private(): No of messages: 0
> > > [136] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [160] MatStashScatterBegin_Private(): No of messages: 0
> > > [160] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [29] MatStashScatterBegin_Private(): No of messages: 0
> > > [29] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [92] MatStashScatterBegin_Private(): No of messages: 0
> > > [92] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [53] MatStashScatterBegin_Private(): No of messages: 0
> > > [53] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [14] MatStashScatterBegin_Private(): No of messages: 0
> > > [14] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [195] MatStashScatterBegin_Private(): No of messages: 0
> > > [195] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [114] MatStashScatterBegin_Private(): No of messages: 0
> > > [114] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [67] MatStashScatterBegin_Private(): No of messages: 0
> > > [67] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [141] MatStashScatterBegin_Private(): No of messages: 0
> > > [141] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [137] MatStashScatterBegin_Private(): No of messages: 0
> > > [137] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [161] MatStashScatterBegin_Private(): No of messages: 0
> > > [161] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [32] MatStashScatterBegin_Private(): No of messages: 0
> > > [32] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [93] MatStashScatterBegin_Private(): No of messages: 0
> > > [93] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [54] MatStashScatterBegin_Private(): No of messages: 0
> > > [54] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [15] MatStashScatterBegin_Private(): No of messages: 0
> > > [15] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [196] MatStashScatterBegin_Private(): No of messages: 0
> > > [196] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [115] MatStashScatterBegin_Private(): No of messages: 0
> > > [115] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [68] MatStashScatterBegin_Private(): No of messages: 0
> > > [68] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [144] MatStashScatterBegin_Private(): No of messages: 0
> > > [144] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [138] MatStashScatterBegin_Private(): No of messages: 0
> > > [138] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [163] MatStashScatterBegin_Private(): No of messages: 0
> > > [163] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [33] MatStashScatterBegin_Private(): No of messages: 0
> > > [33] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [94] MatStashScatterBegin_Private(): No of messages: 0
> > > [94] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [55] MatStashScatterBegin_Private(): No of messages: 0
> > > [55] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [17] MatStashScatterBegin_Private(): No of messages: 0
> > > [17] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [198] MatStashScatterBegin_Private(): No of messages: 0
> > > [198] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [116] MatStashScatterBegin_Private(): No of messages: 0
> > > [116] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [69] MatStashScatterBegin_Private(): No of messages: 0
> > > [69] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [145] MatStashScatterBegin_Private(): No of messages: 0
> > > [145] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [139] MatStashScatterBegin_Private(): No of messages: 0
> > > [139] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [164] MatStashScatterBegin_Private(): No of messages: 0
> > > [164] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [34] MatStashScatterBegin_Private(): No of messages: 0
> > > [34] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [95] MatStashScatterBegin_Private(): No of messages: 0
> > > [95] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [56] MatStashScatterBegin_Private(): No of messages: 0
> > > [56] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [1] MatStashScatterBegin_Private(): No of messages: 0
> > > [1] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [199] MatStashScatterBegin_Private(): No of messages: 0
> > > [199] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [119] MatStashScatterBegin_Private(): No of messages: 0
> > > [119] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [70] MatStashScatterBegin_Private(): No of messages: 0
> > > [70] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [146] MatStashScatterBegin_Private(): No of messages: 0
> > > [146] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [121] MatStashScatterBegin_Private(): No of messages: 0
> > > [121] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [165] MatStashScatterBegin_Private(): No of messages: 0
> > > [165] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [35] MatStashScatterBegin_Private(): No of messages: 0
> > > [35] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [99] MatStashScatterBegin_Private(): No of messages: 0
> > > [99] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [59] MatStashScatterBegin_Private(): No of messages: 0
> > > [59] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [2] MatStashScatterBegin_Private(): No of messages: 0
> > > [2] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [180] MatStashScatterBegin_Private(): No of messages: 0
> > > [180] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [102] MatStashScatterBegin_Private(): No of messages: 0
> > > [102] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [71] MatStashScatterBegin_Private(): No of messages: 0
> > > [71] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [147] MatStashScatterBegin_Private(): No of messages: 0
> > > [147] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [122] MatStashScatterBegin_Private(): No of messages: 0
> > > [122] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [167] MatStashScatterBegin_Private(): No of messages: 0
> > > [167] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [36] MatStashScatterBegin_Private(): No of messages: 0
> > > [36] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [82] MatStashScatterBegin_Private(): No of messages: 0
> > > [82] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [41] MatStashScatterBegin_Private(): No of messages: 0
> > > [41] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [3] MatStashScatterBegin_Private(): No of messages: 0
> > > [3] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [181] MatStashScatterBegin_Private(): No of messages: 0
> > > [181] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [103] MatStashScatterBegin_Private(): No of messages: 0
> > > [103] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [72] MatStashScatterBegin_Private(): No of messages: 0
> > > [72] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [149] MatStashScatterBegin_Private(): No of messages: 0
> > > [149] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [123] MatStashScatterBegin_Private(): No of messages: 0
> > > [123] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [168] MatStashScatterBegin_Private(): No of messages: 0
> > > [168] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [37] MatStashScatterBegin_Private(): No of messages: 0
> > > [37] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [83] MatStashScatterBegin_Private(): No of messages: 0
> > > [83] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [42] MatStashScatterBegin_Private(): No of messages: 0
> > > [42] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [4] MatStashScatterBegin_Private(): No of messages: 0
> > > [4] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [183] MatStashScatterBegin_Private(): No of messages: 0
> > > [183] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [104] MatStashScatterBegin_Private(): No of messages: 0
> > > [104] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [73] MatStashScatterBegin_Private(): No of messages: 0
> > > [73] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [150] MatStashScatterBegin_Private(): No of messages: 0
> > > [150] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [124] MatStashScatterBegin_Private(): No of messages: 0
> > > [124] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [172] MatStashScatterBegin_Private(): No of messages: 0
> > > [172] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [38] MatStashScatterBegin_Private(): No of messages: 0
> > > [38] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [85] MatStashScatterBegin_Private(): No of messages: 0
> > > [85] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [43] MatStashScatterBegin_Private(): No of messages: 0
> > > [43] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [5] MatStashScatterBegin_Private(): No of messages: 0
> > > [5] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [184] MatStashScatterBegin_Private(): No of messages: 0
> > > [184] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [106] MatStashScatterBegin_Private(): No of messages: 0
> > > [106] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [74] MatStashScatterBegin_Private(): No of messages: 0
> > > [74] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [151] MatStashScatterBegin_Private(): No of messages: 0
> > > [151] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [125] MatStashScatterBegin_Private(): No of messages: 0
> > > [125] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [173] MatStashScatterBegin_Private(): No of messages: 0
> > > [173] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [39] MatStashScatterBegin_Private(): No of messages: 0
> > > [39] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [87] MatStashScatterBegin_Private(): No of messages: 0
> > > [87] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [46] MatStashScatterBegin_Private(): No of messages: 0
> > > [46] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [8] MatStashScatterBegin_Private(): No of messages: 0
> > > [8] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [186] MatStashScatterBegin_Private(): No of messages: 0
> > > [186] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [107] MatStashScatterBegin_Private(): No of messages: 0
> > > [107] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [75] MatStashScatterBegin_Private(): No of messages: 0
> > > [75] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [152] MatStashScatterBegin_Private(): No of messages: 0
> > > [152] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [126] MatStashScatterBegin_Private(): No of messages: 0
> > > [126] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [175] MatStashScatterBegin_Private(): No of messages: 0
> > > [175] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [22] MatStashScatterBegin_Private(): No of messages: 0
> > > [22] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [88] MatStashScatterBegin_Private(): No of messages: 0
> > > [88] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [49] MatStashScatterBegin_Private(): No of messages: 0
> > > [49] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [16] MatStashScatterBegin_Private(): No of messages: 0
> > > [16] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [189] MatStashScatterBegin_Private(): No of messages: 0
> > > [189] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [108] MatStashScatterBegin_Private(): No of messages: 0
> > > [108] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [76] MatStashScatterBegin_Private(): No of messages: 0
> > > [76] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [153] MatStashScatterBegin_Private(): No of messages: 0
> > > [153] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [127] MatStashScatterBegin_Private(): No of messages: 0
> > > [127] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [176] MatStashScatterBegin_Private(): No of messages: 0
> > > [176] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [23] MatStashScatterBegin_Private(): No of messages: 0
> > > [23] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [89] MatStashScatterBegin_Private(): No of messages: 0
> > > [89] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [50] MatStashScatterBegin_Private(): No of messages: 0
> > > [50] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [18] MatStashScatterBegin_Private(): No of messages: 0
> > > [18] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [191] MatStashScatterBegin_Private(): No of messages: 0
> > > [191] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [110] MatStashScatterBegin_Private(): No of messages: 0
> > > [110] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [77] MatStashScatterBegin_Private(): No of messages: 0
> > > [77] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [154] MatStashScatterBegin_Private(): No of messages: 0
> > > [154] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [128] MatStashScatterBegin_Private(): No of messages: 0
> > > [128] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [177] MatStashScatterBegin_Private(): No of messages: 0
> > > [177] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [27] MatStashScatterBegin_Private(): No of messages: 0
> > > [27] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [90] MatStashScatterBegin_Private(): No of messages: 0
> > > [90] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [51] MatStashScatterBegin_Private(): No of messages: 0
> > > [51] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [19] MatStashScatterBegin_Private(): No of messages: 0
> > > [19] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [193] MatStashScatterBegin_Private(): No of messages: 0
> > > [193] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [117] MatStashScatterBegin_Private(): No of messages: 0
> > > [117] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [78] MatStashScatterBegin_Private(): No of messages: 0
> > > [78] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [155] MatStashScatterBegin_Private(): No of messages: 0
> > > [155] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [129] MatStashScatterBegin_Private(): No of messages: 0
> > > [129] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [178] MatStashScatterBegin_Private(): No of messages: 0
> > > [178] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [30] MatStashScatterBegin_Private(): No of messages: 0
> > > [30] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [96] MatStashScatterBegin_Private(): No of messages: 0
> > > [96] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [52] MatStashScatterBegin_Private(): No of messages: 0
> > > [52] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [197] MatStashScatterBegin_Private(): No of messages: 0
> > > [197] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [118] MatStashScatterBegin_Private(): No of messages: 0
> > > [118] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [79] MatStashScatterBegin_Private(): No of messages: 0
> > > [79] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [159] MatStashScatterBegin_Private(): No of messages: 0
> > > [159] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [131] MatStashScatterBegin_Private(): No of messages: 0
> > > [131] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [179] MatStashScatterBegin_Private(): No of messages: 0
> > > [179] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [31] MatStashScatterBegin_Private(): No of messages: 0
> > > [31] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [97] MatStashScatterBegin_Private(): No of messages: 0
> > > [97] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [57] MatStashScatterBegin_Private(): No of messages: 0
> > > [57] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [98] MatStashScatterBegin_Private(): No of messages: 0
> > > [98] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [58] MatStashScatterBegin_Private(): No of messages: 0
> > > [58] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [104] MatAssemblyEnd_SeqAIJ(): Matrix size: 81125 X 81125; storage
> space: 3238253 unneeded,493497 used
> > > [104] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [104] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 12
> > > [104] MatCheckCompressedRow(): Found the ratio (num_zerorows
> 0)/(num_localrows 81125) < 0.6. Do not use CompressedRow routines.
> > > [4] MatAssemblyEnd_SeqAIJ(): Matrix size: 81125 X 81125; storage
> space: 3197999 unneeded,533751 used
> > > [4] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [4] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 13
> > > [4] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [106] MatAssemblyEnd_SeqAIJ(): Matrix size: 81125 X 81125; storage
> space: 3243809 unneeded,487941 used
> > > [106] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [106] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 12
> > > [106] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [144] MatAssemblyEnd_SeqAIJ(): Matrix size: 81124 X 81124; storage
> space: 3243446 unneeded,488258 used
> > > [144] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [144] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 11
> > > [144] MatCheckCompressedRow(): Found the ratio (num_zerorows
> 0)/(num_localrows 81124) < 0.6. Do not use CompressedRow routines.
> > > [123] MatAssemblyEnd_SeqAIJ(): Matrix size: 81125 X 81125; storage
> space: 3237359 unneeded,494391 used
> > > [123] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [123] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 12
> > > [123] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [173] MatAssemblyEnd_SeqAIJ(): Matrix size: 81124 X 81124; storage
> space: 3245082 unneeded,486622 used
> > > [173] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [173] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 12
> > > [173] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [85] MatAssemblyEnd_SeqAIJ(): Matrix size: 81125 X 81125; storage
> space: 3217795 unneeded,513955 used
> > > [85] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [85] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 12
> > > [85] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [6] MatAssemblyEnd_SeqAIJ(): Matrix size: 81125 X 81125; storage
> space: 3208633 unneeded,523117 used
> > > [6] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [6] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 13
> > > [6] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [185] MatAssemblyEnd_SeqAIJ(): Matrix size: 81124 X 81124; storage
> space: 3209020 unneeded,522684 used
> > > [185] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [185] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 12
> > > [185] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [108] MatAssemblyEnd_SeqAIJ(): Matrix size: 81125 X 81125; storage
> space: 3216305 unneeded,515445 used
> > > [108] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [108] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 12
> > > [73] MatAssemblyEnd_SeqAIJ(): Matrix size: 81125 X 81125; storage
> space: 3201643 unneeded,530107 used
> > > [73] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [73] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 13
> > > [73] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [146] MatAssemblyEnd_SeqAIJ(): Matrix size: 81124 X 81124; storage
> space: 3234040 unneeded,497664 used
> > > [146] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [146] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 11
> > > [146] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [127] MatAssemblyEnd_SeqAIJ(): Matrix size: 81125 X 81125; storage
> space: 3243435 unneeded,488315 used
> > > [127] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [127] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 12
> > > [127] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [177] MatAssemblyEnd_SeqAIJ(): Matrix size: 81124 X 81124; storage
> space: 3249858 unneeded,481846 used
> > > [177] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [177] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 12
> > > [177] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [27] MatAssemblyEnd_SeqAIJ(): Matrix size: 81125 X 81125; storage
> space: 3207727 unneeded,524023 used
> > > [27] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [27] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 13
> > > [27] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [87] MatAssemblyEnd_SeqAIJ(): Matrix size: 81125 X 81125; storage
> space: 3220647 unneeded,511103 used
> > > [87] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [87] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 12
> > > [87] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [54] MatAssemblyEnd_SeqAIJ(): Matrix size: 81125 X 81125; storage
> space: 3197939 unneeded,533811 used
> > > [54] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [54] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 13
> > > [54] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [8] MatAssemblyEnd_SeqAIJ(): Matrix size: 81125 X 81125; storage
> space: 3179441 unneeded,552309 used
> > > [8] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [8] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 13
> > > [8] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [187] MatAssemblyEnd_SeqAIJ(): Matrix size: 81124 X 81124; storage
> space: 3197890 unneeded,533814 used
> > > [187] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues()
> is 0
> > > [187] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 13
> > > [187] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [108] MatCheckCompressedRow(): Found the ratio (num_zerorows
> > > [74] MatAssemblyEnd_SeqAIJ(): Matrix size: 81125 X 81125; storage
> space: 3200381 unneeded,531369 used
> > > <ex1.c><inp.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150502/c109c896/attachment-0001.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150502/c109c896/attachment-0001.bin>
