[petsc-users] Unequal sparse matrix row distribution for MPI	MatMult
    Matthew Knepley
    knepley at gmail.com
    Tue Mar 31 20:10:16 CDT 2015
On Tue, Mar 31, 2015 at 6:51 PM, Steena M <stm8086 at yahoo.com> wrote:
> Thanks Barry. I'm still getting the malloc error with NULL. Is there a way
> to distribute the matrix without explicit preallocation? Different matrices
> will be loaded during runtime and assigning preallocation parameters would
> mean an additional preprocessing step.
1) MatSetOption(MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE)
2) Note that this is never ever ever more efficient than making another
pass and preallocating
     Matt
> On Sun, 3/29/15, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Subject: Re: [petsc-users] Unequal sparse matrix row distribution for MPI
> MatMult
>  To: "Steena M" <stm8086 at yahoo.com>
>  Cc: "Matthew Knepley" <knepley at gmail.com>, petsc-users at mcs.anl.gov
>  Date: Sunday, March 29, 2015, 9:26 PM
>  > On
>  Mar 29, 2015, at 11:05 PM, Steena M <stm8086 at yahoo.com>
>  wrote:
>  > Thanks
>  Matt. I used PETSC_DETERMINE but I'm now getting an
>  allocation-based error:
>  > [0]PETSC ERROR: ---------------------
>  Error Message ------------------------------------
>  > [0]PETSC ERROR: Argument out of range!
>  > [0]PETSC ERROR: New nonzero at (2,18)
>  caused a malloc!
>  > [0]PETSC ERROR:
>  > I tried
>  preallocating on each rank for the diagonal and off diagonal
>  section of the matrix as the next step  My current
>  approximations for preallocation
>  > CHKERRQ(
>  MatMPIBAIJSetPreallocation(A,1,5,PETSC_DEFAULT,5,PETSC_DEFAULT));
>     These
>  arguments where you pass PETSC_DEFAULT are expecting a
>  pointer not an integer. You can pass NULL in those
>  locations. Though it is better to provide the correct
>  preallocation rather than some defaults.
>    Barry
>  > are throwing segmentation errors.
>  > [0]PETSC ERROR:
>  Caught signal number 11 SEGV: Segmentation Violation,
>  probably memory access out of range
>  > Any insights into what I'm doing
>  wrong?
>  > Thanks,
>  > Steena
>  > On Sun, 3/29/15, Matthew Knepley <knepley at gmail.com>
>  wrote:
>  > Subject:
>  MPI MatMult
>  > To: "Steena M"
>  > Cc: "Barry Smith" <bsmith at mcs.anl.gov>,
>  > Date: Sunday, March 29, 2015, 10:02 PM
>  > On Sun, Mar 29, 2015
>  at
>  > 9:56 PM, Steena M <stm8086 at yahoo.com>
>  > wrote:
>  > Hi
>  > Barry,
>  > I am trying to partition a 20 row and 20
>  col sparse matrix
>  > between two procs
>  such that proc 0 has 15 rows and 20 cols
>  > and proc 1 has 5 rows and 20 cols. The
>  code snippet:
>     CHKERRQ(MatCreate(PETSC_COMM_WORLD,&A));
>  > at runtime: -matload_block_size 1
>     if (rank ==0)
>     CHKERRQ( MatSetSizes(A, 15, 20, 20,
>  > 20) ); //rank 0 gets 75% of the rows
>     CHKERRQ( MatSetType(A, MATMPIBAIJ)
>  >                 CHKERRQ(
>  MatLoad(A,fd) );
>  >         else
>                 CHKERRQ( MatSetSizes(A, 5,
>  20, 20,
>  > 20) ); //rank 1 gets 25% of the
>  rows
>  >                 CHKERRQ(
>  MatLoad(A,fd) );
>  > This throws the following error (probably
>  from psplit.c):
>  [1]PETSC ERROR: --------------------- Error Message
>  > [1]PETSC ERROR:
>  Nonconforming object sizes!
>  > [1]PETSC ERROR: Sum of local lengths 40
>  does not equal
>  > global length 20, my
>  local length 20
>  >   likely a call to
>  VecSetSizes() or MatSetSizes() is
>  wrong.
>  > See
>  http://www.mcs.anl.gov/petsc/documentation/faq.html#split!
>  > This error printout
>  doesn't quite make sense to me.
>  I'm trying to specify a total matrix size of 20x20...
>  I
>  > haven't yet figured out where the
>  '40' comes
>  > from in the error
>  message.
>  > Any thoughts on what
>  might be going wrong?
>  > Its the column specification. Just
>  > use PETSC_DETERMINE for the local columns
>  since all our
>  > sparse matrixformats are
>  row divisions
>  > anyway.
>  > Thanks,
>  >  Matt
>  > Thanks in advance,
>  > Steena
>  > On Sun, 3/22/15,
>  sparse matrix row
>  MatMult
>  >  To:
>  >  Cc: petsc-users at mcs.anl.gov
>  >  Date: Sunday,
>  March 22, 2015, 3:58 PM
>  >  Steena,
>  >     I am
>  >  a little unsure of your question.
>  >     1)
>  you can create a MPIBAIJ
>  >  matrix with any distribution of block
>  rows per process
>  > you
>  >  want, just set the
>  local row size for each process to
>  be
>  >  what you
>  like.  Use MatCreateVecs() to get
>  correspondingly
>  laid out vectors.
>     or 2) if you have a MPIBAIJ
>  >  matrix with
>  "equal" row layout and you want a
>  > new
>  >  one with uneven row layout you can
>  simply use
>  MatGetSubMatrix() to create that new matrix.
>  >    Barry
>  >  Unless you have
>  another reason to have the
>  >  matrix with an equal number row layout I
>  would just
>  > generate
>  >  the matrix with
>  the layout you want.
>  >  > On Mar 22, 2015, at 5:50 PM, Steena
>  M
>  >  wrote:
>  >  > Hello,
>  >  > I need to
>  distribute
>  >  a
>  sparse matrix such that each proc owns an unequal
>  > number
>  >  of blocked rows before I proceed with
>  MPI MatMult. My
>  initial thoughts on doing this:
>  >  > 1) Use  MatGetSubMatrices() on the
>  test
>  >  MATMPIBAIJ
>  matrix to produce a new matrix where each
>  > proc
>  >  has an unequal number of rows.
>  >  > 2) Provide
>  scatter context for vector X
>  >  (for MatMult )using IS iscol from
>  MatGetSubMatrices()
>  > while
>  >  creating the
>  vector X.
>  >  > 3)
>  Call MatMult()
>  >  > Will
>  MatMult_MPIBAIJ continue to scatter
>  >  this matrix and vector such that each
>  proc will own an
>  > equal
>  >  number of matrix
>  rows and corresponding diagonal vector
>  >  elements? Should I write my own
>  MPIMatMult function to
>  >  retain my redistribution of the matrix
>  and vector?
>  Thanks in
>  advance,
>  Steena
>  > What most
>  experimenters
>  > take for granted before
>  they begin their experiments is
>  infinitely more interesting than any results to which
>  their
>  > experiments lead.
>  > -- Norbert
>  > Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150331/d8847929/attachment-0001.html>
