[petsc-users] FEM 101
Matthew Knepley
knepley at gmail.com
Tue Mar 31 15:20:13 CDT 2015
On Tue, Mar 31, 2015 at 2:33 PM, Justin Pogacnik <j.pogacnik at auckland.ac.nz>
wrote:
> Yep, thanks for that Matt. I'll start playing around with the
> PetscFEIntegrate routines in C++. Is there any plan to make those
> accessible in F90?
I will write any wrappers you need for F90. However, I wait until people
ask because its a pain with arrays. There are legit
reasons for writing in F90, but I would think deeply one more time before
committing to a new project in that language.
> Also, I'm not seeing DMPlexIntegrateResidual.
I typed it wrong. Its DMPlexComputeResidualFEM():
https://bitbucket.org/petsc/petsc/src/569f457242c46be7b11883bb57411ddc0c41c340/src/snes/utils/dmplexsnes.c?at=master#cl-1939
Matt
> Thanks for the help,
> Justin
> *From:* Matthew Knepley [knepley at gmail.com]
> *Sent:* Tuesday, March 31, 2015 5:14 PM
> *To:* Justin Pogacnik
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] FEM 101
> On Mon, Mar 30, 2015 at 4:39 PM, Justin Pogacnik <
> j.pogacnik at auckland.ac.nz> wrote:
>> Hello,
>> I'm beginning to write a finite element solid mechanics code in F90 and
>> am having some problems getting started with finite element basics within
>> Petsc. I'm using an unstructured grid and the DMPlex class and able to
>> access most of the mesh information required for FE numerical integration.
>> I've used PetscFECreateDefault and have found the quadrature point
>> locations/data. I'm trying to determine how to find the values of standard
>> trilinear basis functions and their derivatives at the element quadrature
>> points and then to perform the integration on the element. Can anyone
>> advise what the proper routines are that I should call? It's possible that
>> I'm way off target. I've seen "PetscFEGetBasisSpace", but I'm unsure what
>> to do with the resulting output space. I've also seen the PetscFEIntegrate
>> routines, but unsure how their intended to be used and don't see any
>> fortran wrappers.
>> I hope this question is clear. Please let me know if you require more
>> information. I appreciate any help and guidance that anyone can offer.
> Here is the plain vanilla integration routine:
> https://bitbucket.org/petsc/petsc/src/1c9d18e7633f5b782021dca6d8727de2838ee261/src/dm/dt/interface/dtfe.c?at=master#cl-3380
> which is an implementation of PetscFEIntegrate(). The idea is that this
> integrates a bunch of elements, and then there is an outer
> loop over the whole mesh, which is currently DMPlexIntegrateResidual().
> Unfortunately, this function also does a bunch of other
> stuff, and right now I do not see how to simplify it.
> Does this make sense?
> Thanks,
> Matt
>> Many thanks,
>> Justin
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150331/e71bd0ad/attachment-0001.html>
