[petsc-users] HermitianTranspose version of MatCreateTranspose.
Andrew Spott
ansp6066 at colorado.edu
Mon Mar 30 16:27:24 CDT 2015
I submitted a pull request for this: https://bitbucket.org/petsc/petsc/pull-request/291/creates-a-matcreatehermitiantranspose/diff
However, I forgot to pull master before submitting it, and someone added ex180 in the meantime. Should I redo the pull request, or just let the merger fix it?
-Andrew
On Wed, Mar 18, 2015 at 3:10 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Mar 18, 2015, at 3:41 PM, Andrew Spott <ansp6066 at colorado.edu> wrote:
>> So, I’ve got a MatCreateHermitianTranspose function that has close to the same functionality as the MatCreatTranspose version. So I’m getting ready to send a pull request.
> Great
>> A few questions:
>> What branch should I add my changes to?
> master
>> Should I create tests for this?
> most definitely
>> Where should I put them?
> src/mat/examples/tests
>> On Monday, Feb 23, 2015 at 9:02 PM, Barry Smith <bsmith at mcs.anl.gov>, wrote:
>> We've had a small amount of debate over the years on how to handle the Hermitian transpose and non-Hermitian transpose that never got fully resolved.
>> Approach 1) Each (complex) matrix has a full set of transpose and Hermitian transpose operations (MatTranspose(), MatHermitianTranspose(), MatMultTranspose()), MatMultHermitianTranspose(), MatSolveTranspose(), MatSolveHermitianTranspose(), MatMatMultTranspose(), MatMatMultHermitianTranspose(), MatTranposeMatMult(), MatHermitianTransposeMatMult().......) plus there are two vector "inner" products; VecDot() and VecTDot().
>> Approach 2) Consider a (complex) vector (and hence the associated matrix operators on it) to live in the usual Hermitian inner product space or the non-Hermitian "inner product space". Then one only needs a single VecDot() and MatTranspose(), MatMultTranspose() ... that just "does the right thing" based on what space the user has declared the vectors/matrices to be in.
>> Approach 2) seems nicer since it only requires 1/2 the functions :-) and so long as the two vector "spaces" never interact directly (for example what would be the meaning of the "inner" product of a vector in the usual Hermitian inner product space with a vector from the non-Hermitian "inner product space"?) certain seems simpler. Approach 1) might be simpler for some people who like to always see exactly what they are doing.
>> I personally wish I had started with Approach 2 (but I did not), but there could be some flaw with it I am not seeing.
>> Barry
>> > On Feb 23, 2015, at 6:50 PM, Andrew Spott <ansp6066 at colorado.edu> wrote:
>> > I’m definitely willing to submit it as a pull request.
>> > Also, while I’m at it, I’m going to write a “duplicate” function for transpose and hermitian_transpose. Just because this seems 1) easy ( MatHermitianTranspose can return a new copy, as well as MatTranspose), and 2) necessary to use these for EPS.
>> > Also, is “transpose” a good enough MatType? Or does a new one need to be written?
>> > -Andrew
>> > On Mon, Feb 23, 2015 at 3:12 PM, Jed Brown <jed at jedbrown.org> wrote:
>> > <signature.asc>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150330/203a633c/attachment.html>
