[petsc-users] Understanding MatCreate bsize parameter
Florian Lindner
mailinglists at xgm.de
Mon Mar 30 05:59:54 CDT 2015
Am Freitag, 27. März 2015, 07:34:56 schrieb Matthew Knepley:
> On Fri, Mar 27, 2015 at 7:31 AM, Florian Lindner <mailinglists at xgm.de>
> wrote:
> > Am Freitag, 27. März 2015, 07:26:11 schrieb Matthew Knepley:
> > > On Fri, Mar 27, 2015 at 4:28 AM, Florian Lindner <mailinglists at xgm.de>
> > > wrote:
> > > > Am Donnerstag, 26. März 2015, 07:34:27 schrieb Jed Brown:
> > > > > Florian Lindner <mailinglists at xgm.de> writes:
> > > > > > Hello,
> > > > > > I'm using petsc with petsc4py.
> > > > > > A matrix is created like that
> > > > > > MPIrank = MPI.COMM_WORLD.Get_rank()
> > > > > > MPIsize = MPI.COMM_WORLD.Get_size()
> > > > > > print("MPI Rank = ", MPIrank)
> > > > > > print("MPI Size = ", MPIsize)
> > > > > > parts = partitions()
> > > > > > print("Dimension= ", nSupport + dimension, "bsize = ",
> > > > len(parts[MPIrank]))
> > > > > > MPI.COMM_WORLD.Barrier() # Just to keep the output together
> > > > > > A = PETSc.Mat(); A.createDense( (nSupport + dimension,
> > nSupport +
> > > > dimension), bsize = len(parts[MPIrank]) ) # <-- crash here
> > > > > bsize is collective (must be the same on all processes). It is used
> > for
> > > > > vector-valued problems (like elasticity -- bs=3 in 3 dimensions).
> > > > It seems I'm still misunderstanding the bsize parameter.
> > > > If I distribute a 10x10 matrix on three ranks I need to have a
> > > > non-homogenous distribution, and thats what petsc does itself:
> > > blockSize really means the uniform block size of the matrix, thus is HAS
> > to
> > > divide the global size. If it does not,
> > > you do not have a uniform block size, you have a bunch of different sized
> > > blocks.
> > But how can I set a parallel layout when the size of the matrix is not
> > divisable by the number of ranks? When I omit bsize Petsc does that for me,
> > by using block sizes of 4, 3 and 3 on the three different ranks. How can I
> > set such a parallel layout manually?
> I am going to reply in C because it is my native language:
> MatCreate(comm, &A);
> MatSetSizes(A, m, n, PETSC_DETERMINE, PETSC_DETERMINE);
> MatSetFromOptions(A);
> <Preallocation stuff here>
> You have each proc give its local size.
Ok, that seems to be what I'm looking for...
I've experienced some things where my understanding of petsc still seems to be far off, regarding the parallel layout:
I have this code:
ierr = MatSetSizes(matrix, 10, 10, PETSC_DECIDE, PETSC_DECIDE); CHKERRQ(ierr);
MatGetOwnershipRange(matrix, &ownerBegin, &ownerEnd);
cout << "Rank = " << MPIrank << " Begin = " << ownerBegin << " End = " << ownerEnd << endl;
Complete test code: http://pastebin.com/xFM1fJnQ
If started with mpirun -n 3 I it prints
Rank = 2 Begin = 0 End = 10
Rank = 1 Begin = 0 End = 10
Rank = 0 Begin = 0 End = 10
The same happens when I manually set the sizes per processor, like you suggested.
int sizes[] = {4, 3, 3};
MatSetSizes(matrix, sizes[MPIrank], sizes[MPIrank], PETSC_DECIDE, PETSC_DECIDE);
I wonder why the range is always starting from 0, I was rather expecting something like
Rank = 2 Begin = 7 End = 10
Rank = 1 Begin = 4 End = 7
Rank = 0 Begin = 0 End = 4
Petsc4py prints what I expect:
Rank = 1 Range = (4, 7) Size = 3
Rank = 2 Range = (7, 10) Size = 3
Rank = 0 Range = (0, 4) Size = 4
Is this the way it should be?
petsc4py's Mat::setSizes combines MatSetSizes and MatSetBlockSizes. I had some trouble what the correct datatype for size was, but figured it out now:
size = [ (m, M), (n,N) ]
size = [ (sizes[rank], PETSc.DETERMINE), (sizes[rank], PETSc.DETERMINE) ]
The documentation on the python bindings is rather sparse...
Florian
