[petsc-users] Problem with MPI, MatAXPY and SAME_NONZERO_PATTERN
Klaus Kaiser
kaiser at igpm.rwth-aachen.de
Fri Mar 27 09:48:07 CDT 2015
Hallo,
I have a strange behavior in my code concerning the function MatAXPY. I
create 3 different Matrices
ierr = MatCreateBAIJ(PETSC_COMM_WORLD, block_size, local_size,
local_size, system_size, system_size, 0, d_nnz, 0, o_nnz,&A);
ierr = MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
ierr = MatSetOption(A,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
ierr = MatSetOption(A,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
local_size, system_size, system_size, 0, d_nnz, 0, o_nnz,&At);
ierr = MatSetOption(At,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
ierr = MatSetOption(At,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
ierr = MatSetOption(At,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
local_size, system_size, system_size, 0, d_nnz, 0, o_nnz,&Ah);
ierr = MatSetOption(Ah,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
ierr = MatSetOption(Ah,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
ierr = MatSetOption(Ah,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
and want to sum these three matrixes with different factors. First I
fill the Matrix A with some values, and duplicate the structure of A to
the other two matrices:
MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&Ah);
MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&At);
MatAssemblyBegin(Ah,MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(Ah,MAT_FINAL_ASSEMBLY);
MatAssemblyBegin(At,MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(At,MAT_FINAL_ASSEMBLY);
After this I fill the matrices At and Ah with some other values, which
are not beside the non zero structure (I also tried with just copying
the Matrix A). Now after another MatAssembly I want to add these
Matrices in the form A+c*(Ah+d*At):
MatAXPY(Ah,c,At,SAME_NONZERO_PATTERN);
MatAXPY(A,d,Ah,SAME_NONZERO_PATTERN);
When I run the method with mpi and one core everything works fine.
Starting the same method with more cores, the sum of the matrices fails.
It seems like some values are added correctly and many values are
missed. Using DIFFERENT_NONZERO_STRUCTURE leads to the right behavior in
the multi-core case, but is very slow. I checked with a viewer if all
matrices have the same nonzero structure and this is the case.
Does anyone know why this fails, or do I have made any wrong thoughts?
I'm corrently working with a petsc version (Petsc Release Version 3.3.0,
Patch 5, Sat Dec 1 15:10:41 CST 2012), I looked into the changelogs up
to the current version and did not find any note about MatAXPY or MatAYPX.
Best and Thanks a lot for your help
Klaus
