[petsc-users] Error configuring with --download-ml and Intel MKL
David Knezevic
david.knezevic at akselos.com
Thu Mar 26 17:10:29 CDT 2015
On Thu, Mar 26, 2015 at 4:21 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Mar 26, 2015 at 1:48 PM, David Knezevic <
> david.knezevic at akselos.com> wrote:
>> Hi all,
>> I'm trying to configure PETSc using Intel's MKL and with --download-ml.
>> Here is my configure line:
>> ./configure
>> --with-blas-lapack-dir=/opt/intel/composer_xe_2015/mkl/lib/intel64
>> --download-ml
>> I get an error when ML does "checking for dgemm". The configure.log is
>> attached. I was wondering if anyone has any suggestions about how I can get
>> this to work?
> We will need $PETSC_ARCH/externalpackages/ml-*/config.log to see where
> their test failed.
I've attached this file.
> However, MKL is almost never worth it.
OK, interesting, why not? The reason I'm using MKL in this case is because
I found that the direct solvers MUMPS and SuperLU were surprising slow on a
Haswell server. After rebuilding PETSc with MKL, these solvers were more
than 3x faster in some cases.
David
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150326/49f45c69/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150326/49f45c69/attachment-0001.bin>
