[petsc-users] KSP linear solver returns inf
    Matthew Knepley
    knepley at gmail.com
    Thu Mar 26 09:34:27 CDT 2015
On Thu, Mar 26, 2015 at 9:21 AM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
> Hi,
>   I am using the KSP linear solver for my system of equations, without any
> command line options at this point. I have checked that the L1 norms of my
> system matrix and the force vector are finite values, but the KSP solver is
> returning with an “inf” residual in the very first iteration.
>   The problem has 6.7M dofs and I have tried this on multiple machines
> with different number of nodes with the same result.
>    Is there a reason why the solver would return after the first iteration
> with an inf?
>    I am not sure on where to start debugging this case, so I would
> appreciate any pointers.
For all solver questions, we want to see the output of
  -ksp_view -ksp_monitor_true_residual -ksp_converged_reason
The problem here would be that there is an error, so we would never see the
output
of -ksp_view and know what solver you are using. If you are using something
complex,
can you try using
  -pc_type jacobi
and send the output from the options above? Then we can figure out why the
other solver
gets an inf.
     Matt
> Thanks,
> Manav
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150326/dd1c492a/attachment.html>
