[petsc-users] Column #j is wrong in parallel from message "Inserting a new nonzero (i, j) into matrix"
    Eric Chamberland
    Eric.Chamberland at giref.ulaval.ca
    Wed Mar 25 13:20:37 CDT 2015
On 03/25/2015 02:06 PM, Matthew Knepley wrote:
> On Wed, Mar 25, 2015 at 1:03 PM, Eric Chamberland
> <Eric.Chamberland at giref.ulaval.ca
> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
>     Hi,
>     while looking for where in the world do I insert the (135,9) entry
>     in my matrix, I have discovered that the column # shown is wrong in
>     parallel!
> We have talked about this before. It is certainly not easy. The error is
> given by the embedded serial matrix, whereas you want
> the parallel column. It would be good if we could restructure to give
> that back.
Okay!!!  I didn't knew that...
Would it be possible, in parallel, to have the column number marked by a
****** beside it with a footnote like "this is not the column number" in
the error message?  How can it help *me* to have this wrong number?
(just wasted a few hours on this this morning....)
Worded differently: if you take the time to write a message for the end
user, it is to help the programmer right?  But what does it worth if it
does not help, worst, if it mislead the programmer???
Ok, that's it for my 0.5cent...
Thanks for the answer,
Eric
>    Thanks,
>        Matt
>     I am using PETsc 3.5.3.
>     The full error message is:
>     [0]PETSC ERROR: MatSetValues_MPIAIJ() line 564 in
>     /home/mefpp_ericc/petsc-3.5.3/__src/mat/impls/aij/mpi/mpiaij.c
>     Inserting a new nonzero (135, 9) into matrix
>     This line code is a call to a #defined macro:
>     MatSetValues_SeqAIJ_B_Private(__row,col,value,addv);
>     where the "col" parameter is not equal to "in[j]"!!!
>     in gdb, printing "in[j]" gave me:
>     print in[j]
>     $6 = 537
>     while "col" is:
>     print col
>     $7 = 9
>     So, I expected to have a message telling me that (135,537) and not
>     (135,9) is a new entry matrix!!!
>     Would it be a big work to fix this so that the col # displayed is
>     correct?
>     Thanks!
>     Eric
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
