[petsc-users] petsc4py: Passing command line switches
Florian Lindner mailinglists at xgm.de
Wed Mar 25 10:29:37 CDT 2015
Am Mittwoch, 25. März 2015, 10:17:45 schrieb Matthew Knepley:
> On Wed, Mar 25, 2015 at 10:13 AM, Florian Lindner <mailinglists at xgm.de>
> wrote:
> > Hello,
> > I'm using the petsc4py. It works fine after some hurdling with missing
> > documentation. (were not able to find API doc anywhere, I generated it
> > myself now).
> > I try to use the switches like -ksp_monitor like that:
> > import petsc4py
> > from petsc4py import PETSc
> > petsc4py.init(sys.argv)
> > but no reaction when calling my script like that:
> > python prbf.py -ksp_monitor
> > What am I doing wrong? I also tried calling init before importing PETSc
> > but no changes.
> Did you remember to call setFromOptions() on the KSP? We do not configure
> anything from
> the command line unless you tell us to. That way, people can do things
> solely from the API
> is they want.
Double fail from my said.
I works when called like that:
import petsc4py
Importing PETSc probably calls init and subsequent calls have no effect.
> How did you generate the documentation?
Second fail. I tried to generate it yesterday after I cloned the git and was unable to generate myself. make html does not brought much sphinx doc. Then I learned that the tarball contains an epydoc. Is that available online somewhere?
The online repo is a bit confusing, it contains an index.rst https://bitbucket.org/petsc/petsc4py/src/9dce29cab0b03f4d75fdebab087575b9635bd206/docs/index.rst?at=master
but this file seems to be competely dysfunctional. It looks like links in the document but nothing clickable (I can't even mark test), the Blame/Embed/Raw also seem dysfunctional.
Florian
>   Thanks,
>     Matt
> > Thanks,
> > Florian
