[petsc-users] TimeStepper norm problems. EMIL Please read this
Lisandro Dalcin dalcinl at gmail.com
Tue Mar 24 05:20:44 CDT 2015
On 24 March 2015 at 01:34, Jed Brown <jed at jedbrown.org> wrote:
> Lisandro Dalcin <dalcinl at gmail.com> writes:
>> On 21 March 2015 at 17:32, Emil Constantinescu <emconsta at mcs.anl.gov> wrote:
>>> When -ts_theta_adapt is used, then it detects the instability as an error
>>> and reduces the step by a lot! wlte=1.24e+03 which means that the reduction
>>> should be severe but the controller tries 0.1*dt and that seems to pass but
>>> it "jig-saws" (take a look at the next attempted step), which means that it
>>> is likely unstable.
>> I think -ts_theta_adapt is seriously broken, I cannot make sense of
>> the way the error estimator is computed.
> This was Shri's implementation.  TSEvaluateStep_Theta looks wrong to me,
> both using U as an input and assuming that Xdot is set.  I don't even
> know what the intended math is for a first-order embedded estimate in
> midpoint (theta=0.5).
Pease note that -ts_adapt_tetha errors for midpoint. You actually need
-ts_theta_endpoint to use adaptivity. But it is there, in the endpoint
version, that I cannot make sense of the implementation. The
trapezoidal rule is second-order, thus the LTE is O(dt^3). The
computed error estimator should be O(dt^2), but the current code seems
to compute an estimator O(dt), and that's the root of all evil.
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Numerical Porous Media Center (NumPor)
King Abdullah University of Science and Technology (KAUST)
http://numpor.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 4332
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
