[petsc-users] TimeStepper norm problems. EMIL Please read this
    Jed Brown
    jed at jedbrown.org
    Mon Mar 23 17:34:29 CDT 2015
Lisandro Dalcin <dalcinl at gmail.com> writes:
> On 21 March 2015 at 17:32, Emil Constantinescu <emconsta at mcs.anl.gov> wrote:
>> When -ts_theta_adapt is used, then it detects the instability as an error
>> and reduces the step by a lot! wlte=1.24e+03 which means that the reduction
>> should be severe but the controller tries 0.1*dt and that seems to pass but
>> it "jig-saws" (take a look at the next attempted step), which means that it
>> is likely unstable.
> I think -ts_theta_adapt is seriously broken, I cannot make sense of
> the way the error estimator is computed.
This was Shri's implementation.  TSEvaluateStep_Theta looks wrong to me,
both using U as an input and assuming that Xdot is set.  I don't even
know what the intended math is for a first-order embedded estimate in
midpoint (theta=0.5).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150323/493e5d85/attachment.pgp>
