[petsc-users] Object is in wrong state, Matrix is missing diagonal entry
    Khai Pham
    khaipham at utexas.edu
    Mon Mar 23 09:28:01 CDT 2015
Hi Matt,
Thank you for your suggestion. It solves the problem.
Khai
On Mon, Mar 23, 2015 at 8:47 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Mar 23, 2015 at 7:41 AM, Khai Pham <khaipham at utexas.edu> wrote:
>> Dear Petsc-Users,
>> I received the below error message. There could be some error in the
>> matrix assembly and I try to find it out. Based on the error message, could
>> you give me any hint where should I focus on for finding the bug ? Thanks
> If you want to use ILU, we require that a diagonal element exists in the
> matrix. If it is 0, you must explicitly
> set the 0.
>   Thanks,
>      Matt
>> Khai
>> [2]PETSC ERROR: --------------------- Error Message
>> [2]PETSC ERROR: Object is in wrong state
>> [2]PETSC ERROR: Matrix is missing diagonal entry 1
>> [2]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [2]PETSC ERROR: Petsc Release Version 3.5.1, Jul, 24, 2014
>> [2]PETSC ERROR: ./3DMMF on a arch-linux2-c-debug named khp by khp Mon Mar
>> 23 08:24:40 2015
>> [2]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>> --with-fc=gfortran --download-fblaslapack --download-mpich --download-hdf5
>> --download-metis --download-parmetis
>> [2]PETSC ERROR: #1 MatILUFactorSymbolic_SeqAIJ() line 1738 in
>> /home/khp/bin/petsc-3.5.1/src/mat/impls/aij/seq/aijfact.c
>> [2]PETSC ERROR: #2 MatILUFactorSymbolic() line 6203 in
>> /home/khp/bin/petsc-3.5.1/src/mat/interface/matrix.c
>> [2]PETSC ERROR: #3 PCSetUp_ILU() line 206 in
>> /home/khp/bin/petsc-3.5.1/src/ksp/pc/impls/factor/ilu/ilu.c
>> [2]PETSC ERROR: #4 PCSetUp() line 902 in
>> /home/khp/bin/petsc-3.5.1/src/ksp/pc/interface/precon.c
>> [2]PETSC ERROR: #5 KSPSetUp() line 305 in
>> /home/khp/bin/petsc-3.5.1/src/ksp/ksp/interface/itfunc.c
>> [2]PETSC ERROR: #6 PCSetUpOnBlocks_BJacobi_Singleblock() line 651 in
>> /home/khp/bin/petsc-3.5.1/src/ksp/pc/impls/bjacobi/bjacobi.c
>> [2]PETSC ERROR: #7 PCSetUpOnBlocks() line 935 in
>> [2]PETSC ERROR: #8 KSPSetUpOnBlocks() line 166 in
>> [2]PETSC ERROR: #9 KSPSolve() line 418 in
>> [2]PETSC ERROR: #10 SNESSolve_NEWTONLS() line 232 in
>> /home/khp/bin/petsc-3.5.1/src/snes/impls/ls/ls.c
>> [2]PETSC ERROR: #11 SNESSolve() line 3743 in
>> /home/khp/bin/petsc-3.5.1/src/snes/interface/snes.c
>> [2]PETSC ERROR: #12 PF_solver() line 63 in src/PF_solver.cpp
>> [1]PETSC ERROR: --------------------- Error Message
>> [1]PETSC ERROR: Object is in wrong state
>> [1]PETSC ERROR: Matrix is missing diagonal entry 0
>> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> [1]PETSC ERROR: Petsc Release Version 3.5.1, Jul, 24, 2014
>> [1]PETSC ERROR: ./3DMMF on a arch-linux2-c-debug named khp by khp Mon Mar
>> 23 08:24:40 2015
>> [1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>> [1]PETSC ERROR: #1 MatILUFactorSymbolic_SeqAIJ() line 1738 in
>> [1]PETSC ERROR: #2 MatILUFactorSymbolic() line 6203 in
>> [1]PETSC ERROR: #3 PCSetUp_ILU() line 206 in
>> [1]PETSC ERROR: #4 PCSetUp() line 902 in
>> [1]PETSC ERROR: #5 KSPSetUp() line 305 in
>> [1]PETSC ERROR: #6 PCSetUpOnBlocks_BJacobi_Singleblock() line 651 in
>> [1]PETSC ERROR: #7 PCSetUpOnBlocks() line 935 in
>> [1]PETSC ERROR: #8 KSPSetUpOnBlocks() line 166 in
>> [1]PETSC ERROR: #9 KSPSolve() line 418 in
>> [1]PETSC ERROR: #10 SNESSolve_NEWTONLS() line 232 in
>> [1]PETSC ERROR: #11 SNESSolve() line 3743 in
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150323/4e3951ad/attachment-0001.html>
