[petsc-users] TimeStepper norm problems. EMIL Please read this
    Andrew Spott
    ansp6066 at colorado.edu
    Sun Mar 22 21:23:26 CDT 2015
Thanks! Let me know if I can do anything to help.
-Andrew
Andrew
On Sun, Mar 22, 2015 at 8:21 PM, Emil Constantinescu <emconsta at mcs.anl.gov>
wrote:
> Hi Andrew,
> I can reproduce this issue and I agree that there is something wrong.
> I'll look into it.
> Emil
> On 3/22/15 3:29 PM, Andrew Spott wrote:
>> So, I’m now even more confused.
>> I’m attempting to solve an equation that looks like this:
>> u’ = -i(H0 + e(t) D) u
>> Where H0 is a purely real diagonal matrix, D is an off-diagonal block
>> matrix, and e(t) is a function of time (The schrödinger equation in the
>> energy basis).
>> I’ve rewritten the e(t) function in my code to just return 0.0.  So the
>> new equation is just u’ = -iH0 u.  The matrix is time independent and
>> diagonal (I’ve checked this).  H0[0] ~= -.5 (with no imaginary
>> component).  and u(t=0) = [1,0,0,0,..]
>> This problem SHOULD be incredibly simple: u’ = i (0.5) u.
>> However, I’m still getting the same blowup with the TS.:
>> //with e(t) == 0
>> //TS
>> t: 0 step: 0 norm-1: 0
>> t: 0.01 step: 1 norm-1: 0
>> t: 0.02 step: 2 norm-1: 0.9999953125635765
>> t: 0.03 step: 3 norm-1: 2.999981250276277
>> //Hand rolled
>> t: 0.01 norm-1: 0 ef 0
>> t: 0.02 norm-1: 0 ef 0
>> t: 0.03 norm-1: -1.110223024625157e-16 ef 0
>> //with e(t) != 0
>> //TS
>> //Hand rolled
>> t: 0.01 norm-1: 0 ef 9.474814647559372e-11
>> t: 0.02 norm-1: 0 ef 7.57983838406065e-10
>> t: 0.03 norm-1: -1.110223024625157e-16 ef 2.558187954267552e-09
>> I’ve updated the gist.
>> -Andrew
>> On Fri, Mar 20, 2015 at 9:57 PM, Barry Smith <bsmith at mcs.anl.gov
>> <mailto:bsmith at mcs.anl.gov>> wrote:
>>     Andrew,
>>     I'm afraid Emil will have to take a look at this and explain it. The
>>     -ts_type beuler and -ts_type theta -ts_theta_theta .5 are stable but
>>     the -ts_type cn is not stable. It turns out that -ts_type cn is
>>     equivalent to -ts_type theta -ts_theta_theta .5 -ts_theta_endpoint
>>     and somehow this endpoint business (which I don't understand) is
>>     causing a problem. Meanwhile if I add -ts_theta_adapt to the
>>     endpoint one it becomes stable ? Anyways all cases are displayed below.
>>     Emil,
>>     What's up with this? Does the endpoint business have a bug or can it
>>     not be used for this problem (the matrix A is a function of t.)
>>     Barry
>>     $ ./ex2 -ts_type cn
>>     t: 0.02 step: 2 norm-1: 1
>>     t: 0.03 step: 3 norm-1: 3
>>     ~/Src/petsc/test-dir (barry/more-tchem-work *=) arch-debug
>>     $ ./ex2 -ts_type theta
>>     t: 0.03 step: 3 norm-1: 0
>>     $ ./ex2 -ts_type theta -ts_theta_theta .5
>>     $ ./ex2 -ts_type theta -ts_theta_theta .5 -ts_theta_endpoint
>>     -ts_theta_adapt
>>     -ts_theta_adapt -ts_monitor
>>     0 TS dt 0.01 time 0
>>     0 TS dt 0.01 time 0
>>     1 TS dt 0.1 time 0.01
>>     2 TS dt 0.1 time 0.02
>>     3 TS dt 0.1 time 0.03
>>     -ts_theta_adapt -ts_monitor -ts_adapt_monitor
>>     0 TS dt 0.01 time 0
>>     0 TS dt 0.01 time 0
>>     TSAdapt 'basic': step 0 accepted t=0 + 1.000e-02 wlte= 0
>>     family='theta' scheme=0:'(null)' dt=1.000e-01
>>     TSAdapt 'basic': step 1 rejected t=0.01 + 1.000e-01 wlte=1.24e+03
>>     family='theta' scheme=0:'(null)' dt=1.000e-02
>>     TSAdapt 'basic': step 1 accepted t=0.01 + 1.000e-02 wlte= 0
>>     TSAdapt 'basic': step 2 rejected t=0.02 + 1.000e-01 wlte=1.24e+03
>>     TSAdapt 'basic': step 2 accepted t=0.02 + 1.000e-02 wlte= 0
>>     $ ./ex2 -ts_type beuler
>>     $ ./ex2 -ts_type euler
>>      > On Mar 20, 2015, at 10:18 PM, Andrew Spott
>>     <ansp6066 at colorado.edu> wrote:
>>      > here are the data files.
>>      > dipole_matrix.dat:
>>      > https://www.dropbox.com/s/2ahkljzt6oo9bdr/dipole_matrix.dat?dl=0
>>      > energy_eigenvalues_vector.dat
>>     https://www.dropbox.com/s/sb59q38vqvjoypk/energy_eigenvalues_vector.dat?dl=0
>>      > -Andrew
>>      > On Fri, Mar 20, 2015 at 7:25 PM, Barry Smith <bsmith at mcs.anl.gov>
>>     wrote:
>>      > Data files are needed
>>      > PetscViewerBinaryOpen( PETSC_COMM_WORLD,
>>     "hamiltonian/energy_eigenvalues_vector.dat", FILE_MODE_READ, &view );
>>      > VecLoad( H0, view );
>>     "hamiltonian/dipole_matrix.dat", FILE_MODE_READ, &view );
>>      > BTW: You do not need to call Mat/VecAssembly on Mats and Vecs
>>     after they have been loaded.
>>      > Barry
>>      > > On Mar 20, 2015, at 6:39 PM, Andrew Spott
>>      > > Sorry it took so long, I wanted to create a “reduced” case
>>     (without all my parameter handling and other stuff…)
>>      > > https://gist.github.com/spott/aea8070f35e79e7249e6
>>      > > The first section does it using the time stepper. The second
>>     section does it by explicitly doing the steps. The output is:
>>      > > //first section, using TimeStepper:
>>      > > //Second section, using explicit code.
>>      > > t: 0.01 norm-1: 0
>>      > > t: 0.02 norm-1: 0
>>      > > t: 0.02 norm-1: 2.22045e-16
>>      > > On Fri, Mar 20, 2015 at 4:45 PM, Barry Smith
>>     <bsmith at mcs.anl.gov> wrote:
>>      > > Andrew,
>>      > > Send your entire code. It will be easier and faster than
>>     talking past each other.
>>      > > Barry
>>      > > > On Mar 20, 2015, at 5:00 PM, Andrew Spott
>>      > > > I’m sorry, I’m not trying to be difficult, but I’m not
>>     following.
>>      > > > The manual states (for my special case):
>>      > > > • u ̇ = A(t)u. Use
>>      > > > TSSetProblemType(ts,TS LINEAR);
>>     TSSetRHSFunction(ts,NULL,TSComputeRHSFunctionLinear,NULL);
>>     TSSetRHSJacobian(ts,A,A,YourComputeRHSJacobian,&appctx);
>>      > > > where YourComputeRHSJacobian() is a function you provide that
>>     computes A as a function of time. Or use ...
>>      > > > My `func` does this. It is 7 lines:
>>      > > > context* c = static_cast<context*>( G_u );
>>      > > > PetscScalar e = c->E( t_ );
>>      > > > MatCopy( c->D, A, SAME_NONZERO_PATTERN );
>>      > > > MatShift( A, e );
>>      > > > MatDiagonalSet( A, c->H0, INSERT_VALUES);
>>      > > > MatShift( A, std::complex<double>( 0, -1 ) );
>>      > > > return 0;
>>      > > > SHOULD `func` touch U? If so, what should `func` do to U? I
>>     thought that the RHSJacobian function was only meant to create A,
>>     since dG/du = A(t) (for this special case).
>>      > > > -Andrew
>>      > > > On Fri, Mar 20, 2015 at 3:26 PM, Matthew Knepley
>>     <knepley at gmail.com> wrote:
>>      > > > On Fri, Mar 20, 2015 at 3:09 PM, Andrew Spott
>>      > > > So, it doesn’t seem that zeroing the given vector in the
>>     function passed to TSSetRHSJacobian is the problem. When I do that,
>>     it just zeros out the solution.
>>      > > > I would think you would zero the residual vector (if you add
>>     to it to construct the residual, as in FEM methods), not the solution.
>>      > > > The function that is passed to TSSetRHSJacobian has only one
>>     responsibility — to create the jacobian — correct? In my case this
>>     is A(t). The solution vector is given for when you are solving
>>     nonlinear problems (A(t) also depends on U(t)). In my case, I don’t
>>     even look at the solution vector (because my A(t) doesn’t depend on
>>     it).
>>      > > > Are you initializing the Jacobian to 0 first?
>>      > > > Thanks,
>>      > > > Matt
>>      > > > Is this the case? or is there some other responsibility of
>>     said function?
>>      > > > -Andrew
>>      > > > >Ah ha!
>>      > > > >The function passed to TSSetRHSJacobian needs to zero the
>>     solution vector?
>>      > > > >As a point, this isn’t mentioned in any documentation that I
>>     can find.
>>      > > > >-Andrew
>>      > > > On Friday, Mar 20, 2015 at 2:17 PM, Matthew Knepley
>>     <knepley at gmail.com>, wrote:
>>      > > > This sounds like a problem in your calculation function where
>>     a Vec or Mat does not get reset to 0, but it does in your by hand code.
>>      > > > Matt
>>      > > > On Mar 20, 2015 2:52 PM, "Andrew Spott"
>>      > > > I have a fairly simple problem that I’m trying to timestep:
>>      > > > u’ = A(t) u
>>      > > > I’m using the crank-nicholson method, which I understand (for
>>     this problem) to be:
>>      > > > u(t + h) = u(t) + h/2[A(t+h)*u(t+h) + A(t)*u(t)]
>>      > > > or
>>      > > > [1 - h/2 * A(t+1)] u(t+1) = [1 + h/2 * A(t)] u(t)
>>      > > > When I attempt to timestep using PETSc, the norm of `u` blows
>>     up. When I do it directly (using the above), the norm of `u` doesn’t
>>     blow up.
>>      > > > It is important to note that the solution generated after the
>>     first step is identical for both, but the second step for Petsc has
>>     a norm of ~2, while for the directly calculated version it is ~1.
>>     The third step for petsc has a norm of ~4, while the directly
>>     calculated version it is still ~1.
>>      > > > I’m not sure what I’m doing wrong.
>>      > > > PETSc code is taken out of the manual and is pretty simple:
>>      > > > TSCreate( comm, &ts );
>>      > > > TSSetProblemType( ts, TS_LINEAR);
>>      > > > TSSetType( ts, TSCN );
>>      > > > TSSetInitialTimeStep( ts, 0, 0.01 );
>>      > > > TSSetDuration( ts, 5, 0.03 );
>>      > > > TSSetFromOptions( ts );
>>      > > > TSSetRHSFunction( ts, NULL, TSComputeRHSFunctionLinear, NULL );
>>      > > > TSSetRHSJacobian( ts, A, A, func, &cntx );
>>      > > > TSSolve( ts, psi0 );
>>      > > > `func` just constructs A(t) at the time given. The same code
>>     for calculating A(t) is used in both calculations, along with the
>>     same initial vector psi0, and the same time steps.
>>      > > > Let me know what other information is needed. I’m not sure
>>     what could be the problem. `func` doesn’t touch U at all (should it?).
>>      > > > -Andrew
>>      > > > What most experimenters take for granted before they begin
>>     their experiments is infinitely more interesting than any results to
>>     which their experiments lead.
>>      > > > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150322/26419ca0/attachment-0001.html>
