[petsc-users] TimeStepper norm problems.
Andrew Spott
ansp6066 at colorado.edu
Fri Mar 20 22:18:55 CDT 2015
here are the data files.
dipole_matrix.dat:
https://www.dropbox.com/s/2ahkljzt6oo9bdr/dipole_matrix.dat?dl=0
energy_eigenvalues_vector.dat
https://www.dropbox.com/s/sb59q38vqvjoypk/energy_eigenvalues_vector.dat?dl=0
-Andrew
On Fri, Mar 20, 2015 at 7:25 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Data files are needed
> PetscViewerBinaryOpen( PETSC_COMM_WORLD, "hamiltonian/energy_eigenvalues_vector.dat", FILE_MODE_READ, &view );
> VecLoad( H0, view );
> PetscViewerBinaryOpen( PETSC_COMM_WORLD, "hamiltonian/dipole_matrix.dat", FILE_MODE_READ, &view );
> BTW: You do not need to call Mat/VecAssembly on Mats and Vecs after they have been loaded.
> Barry
>> On Mar 20, 2015, at 6:39 PM, Andrew Spott <ansp6066 at colorado.edu> wrote:
>> Sorry it took so long, I wanted to create a “reduced” case (without all my parameter handling and other stuff…)
>> https://gist.github.com/spott/aea8070f35e79e7249e6
>> The first section does it using the time stepper. The second section does it by explicitly doing the steps. The output is:
>> //first section, using TimeStepper:
>> t: 0 step: 0 norm-1: 0
>> t: 0.01 step: 1 norm-1: 0
>> t: 0.02 step: 2 norm-1: 0.999995
>> t: 0.03 step: 3 norm-1: 2.99998
>> //Second section, using explicit code.
>> t: 0.01 norm-1: 0
>> t: 0.02 norm-1: 0
>> t: 0.02 norm-1: 2.22045e-16
>> On Fri, Mar 20, 2015 at 4:45 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> Andrew,
>> Send your entire code. It will be easier and faster than talking past each other.
>> Barry
>> > On Mar 20, 2015, at 5:00 PM, Andrew Spott <ansp6066 at colorado.edu> wrote:
>> > I’m sorry, I’m not trying to be difficult, but I’m not following.
>> > The manual states (for my special case):
>> > • u ̇ = A(t)u. Use
>> > TSSetProblemType(ts,TS LINEAR); TSSetRHSFunction(ts,NULL,TSComputeRHSFunctionLinear,NULL); TSSetRHSJacobian(ts,A,A,YourComputeRHSJacobian,&appctx);
>> > where YourComputeRHSJacobian() is a function you provide that computes A as a function of time. Or use ...
>> > My `func` does this. It is 7 lines:
>> > context* c = static_cast<context*>( G_u );
>> > PetscScalar e = c->E( t_ );
>> > MatCopy( c->D, A, SAME_NONZERO_PATTERN );
>> > MatShift( A, e );
>> > MatDiagonalSet( A, c->H0, INSERT_VALUES);
>> > MatShift( A, std::complex<double>( 0, -1 ) );
>> > return 0;
>> > SHOULD `func` touch U? If so, what should `func` do to U? I thought that the RHSJacobian function was only meant to create A, since dG/du = A(t) (for this special case).
>> > -Andrew
>> > On Fri, Mar 20, 2015 at 3:26 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> > On Fri, Mar 20, 2015 at 3:09 PM, Andrew Spott <ansp6066 at colorado.edu> wrote:
>> > So, it doesn’t seem that zeroing the given vector in the function passed to TSSetRHSJacobian is the problem. When I do that, it just zeros out the solution.
>> > I would think you would zero the residual vector (if you add to it to construct the residual, as in FEM methods), not the solution.
>> > The function that is passed to TSSetRHSJacobian has only one responsibility — to create the jacobian — correct? In my case this is A(t). The solution vector is given for when you are solving nonlinear problems (A(t) also depends on U(t)). In my case, I don’t even look at the solution vector (because my A(t) doesn’t depend on it).
>> > Are you initializing the Jacobian to 0 first?
>> > Thanks,
>> > Matt
>> > Is this the case? or is there some other responsibility of said function?
>> > -Andrew
>> > >Ah ha!
>> > >The function passed to TSSetRHSJacobian needs to zero the solution vector?
>> > >As a point, this isn’t mentioned in any documentation that I can find.
>> > >-Andrew
>> > On Friday, Mar 20, 2015 at 2:17 PM, Matthew Knepley <knepley at gmail.com>, wrote:
>> > This sounds like a problem in your calculation function where a Vec or Mat does not get reset to 0, but it does in your by hand code.
>> > Matt
>> > On Mar 20, 2015 2:52 PM, "Andrew Spott" <ansp6066 at colorado.edu> wrote:
>> > I have a fairly simple problem that I’m trying to timestep:
>> > u’ = A(t) u
>> > I’m using the crank-nicholson method, which I understand (for this problem) to be:
>> > u(t + h) = u(t) + h/2[A(t+h)*u(t+h) + A(t)*u(t)]
>> > or
>> > [1 - h/2 * A(t+1)] u(t+1) = [1 + h/2 * A(t)] u(t)
>> > When I attempt to timestep using PETSc, the norm of `u` blows up. When I do it directly (using the above), the norm of `u` doesn’t blow up.
>> > It is important to note that the solution generated after the first step is identical for both, but the second step for Petsc has a norm of ~2, while for the directly calculated version it is ~1. The third step for petsc has a norm of ~4, while the directly calculated version it is still ~1.
>> > I’m not sure what I’m doing wrong.
>> > PETSc code is taken out of the manual and is pretty simple:
>> > TSCreate( comm, &ts );
>> > TSSetProblemType( ts, TS_LINEAR);
>> > TSSetType( ts, TSCN );
>> > TSSetInitialTimeStep( ts, 0, 0.01 );
>> > TSSetDuration( ts, 5, 0.03 );
>> > TSSetFromOptions( ts );
>> > TSSetRHSFunction( ts, NULL, TSComputeRHSFunctionLinear, NULL );
>> > TSSetRHSJacobian( ts, A, A, func, &cntx );
>> > TSSolve( ts, psi0 );
>> > `func` just constructs A(t) at the time given. The same code for calculating A(t) is used in both calculations, along with the same initial vector psi0, and the same time steps.
>> > Let me know what other information is needed. I’m not sure what could be the problem. `func` doesn’t touch U at all (should it?).
>> > -Andrew
>> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150320/ef0fae6d/attachment.html>
