[petsc-users] Load Vec from 1D HDF5 dataset MATT READ THIS EMAIL!
Thu Mar 19 21:05:35 CDT 2015
>   Ok here is the scoop.  In  VecView_MPI_HDF5() is the code (use meta x
> vc-annotate in emacs)
> df09a399 src/vec/vec/impls/mpi/pdvec.c (Matthew Knepley      2011-01-20
> 16:27:23 -0600  682)   if (bs >= 1) {
> 272345b0 src/vec/vec/impls/mpi/pdvec.c (Karl Rupp            2013-01-26
> 20:27:50 -0600  683)     dims[dim]      = bs;
> 20:27:50 -0600  684)     maxDims[dim]   = dims[dim];
> 61ea93a1 src/vec/vec/impls/mpi/pdvec.c (Brad Aagaard         2010-11-06
> 15:31:18 -0700  685)     chunkDims[dim] = dims[dim];
> 43c8710a src/vec/vec/impls/mpi/pdvec.c (Matthew Knepley      2010-11-05
> 19:21:58 -0500  686)     ++dim;
> 5464dd29 src/vec/vec/impls/mpi/pdvec.c (Matthew Knepley      2010-10-31
> 19:04:52 -0500  687)   }  if (bs >= 1) {
>   then in PetscErrorCode VecLoad_HDF5(Vec xin, PetscViewer viewer)
>   f6e5521d src/vec/vec/utils/vecio.c     (Karl Rupp            2013-01-28
> 13:32:07 -0600 277) if (bs >= 1) ++dim;
> I check the commit message for df09a399 at bitbucket.com/petsc/petsc/ and
> it is
> Small change to HDF5 output (now Vec always has blocksize dim)
> So what is happening is even the simplest vector (with a block size of 1)
> is treated as a 2d HDF5 object
> Matt, what was the rational for making vectors always have a dimension of
> block size even when it is one? Seems bad to me. Maybe makes HDF5 readers
> simpler since they don't need to handle bs 1 differently?
My rationale was to simplify our code path, and have one way to handle
fields with components. I did not
want to special case a field with one component.
     Matt
>  Barry
> > On Mar 19, 2015, at 12:31 PM, Håkon Strandenes <haakon at hakostra.net>
> wrote:
> > I'm sorry I didn't include this in the first email. Here is an example
> HDF5-file, together with a sample program that demonstrate the problem.
> > I have been trying to dig into VecLoad_HDF5() in vecio.c in order to
> suggest a solution myself, however, I do not think I fully understand the
> concept of the Vec block size and how that affects how the Vec is stored in
> memory and on disk (HDF5 file).
> > Regards,
> > Håkon Strandenes
> > On 19. mars 2015 18:17, Barry Smith wrote:
> >>   Please email the file in.h5 so we can try to reproduce the problem
> and debug it. Are you using petsc version 3.5.?
> >>   Barry
> >>> On Mar 19, 2015, at 4:19 AM, Håkon Strandenes <haakon at hakostra.net>
> wrote:
> >>> Hi,
> >>> I am again in trouble with PETSc and its HDF5-related functions.
> >>> I have a code in which I want to read a 1D dataset from a HDF5 file
> into a PETSc Vec. The array are "small", and each MPI process should read
> the entire dataset and store it in its own sequential Vec.
> >>> Currently my code is as follows (somewhat simplified):
> >>> VecCreate(PETSC_COMM_SELF, &v);
> >>> VecSetType(v, VECSEQ);
> >>> PetscObjectSetName((PetscObject)v, "x");
> >>> PetscViewerHDF5Open(PETSC_COMM_WORLD, "in.h5", FILE_MODE_READ,
> &viewer);
> >>> VecLoad(v, viewer);
> >>> This works, but only if the dataset in the HDF5 file is a 2D dataset,
> of size Nx1, where N is the number of elements I read. If the dataset in
> the HDF5 file is of size N (i.e. a 1D dataset) this does not work.
> >>> The error message I get is the following:
> >>> [0]PETSC ERROR: Unexpected data in file
> >>> [0]PETSC ERROR: Dimension of array in file 1 not 2 as expected
> >>> etc. and it points back to the line 296 in file vecio.c, function
> VecLoad_HDF5().
> >>> Technically this is not a problem. I could of course just go ahead and
> "reshape" all my datasets into 2D datasets. I do however find this
> behaviour very un-logical. Why can't I read a 1D dataset into a Vec?
> >>> So my question are:
> >>> 1) Do I do anything wrong when creating my Vec and reading my datasets?
> >>> 2) Is there anything I can do to read my 1D datasets into Vecs?
> >>> 3) Could PETSc perhaps be a little less restrictive in these cases?
> >>> Thanks in advance.
> >>> Regards,
> >>> Håkon Strandenes
> > <VecLoadTest.tar.gz>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150319/5d634821/attachment-0001.html>
