[petsc-users] Questions about MatConvert BAIJ to AIJ
Barry Smith
bsmith at mcs.anl.gov
Wed Mar 18 15:09:40 CDT 2015
> On Mar 18, 2015, at 3:07 PM, Chung-Kan Huang <ckhuangf at gmail.com> wrote:
> So I guess I misunderstood the meaning of " inplace conversion".
> and what do MAT_INITIAL_MATRIX and MAT_REUSE_MATRIX do anyway?
No you have not misunderstood it.
Currently
MAT_REUSE_MATRIX is only supported for inplace conversion, otherwise use
MAT_INITIAL_MATRIX.
For testing purposes you can use MAT_INITIAL_MATRIX.
> On Wed, Mar 18, 2015 at 2:48 PM, Jed Brown <jed at jedbrown.org> wrote:
> Chung-Kan Huang <ckhuangf at gmail.com> writes:
> > Yes, I was suprised that I can still use MatSetValuesBlocked after I did
> > MatConvert MATBAIJ to MATAIJ.
> > Then I just found the mat type is still seqbaij which means the MatConvert
> > didn't work.
> > This is how I did MatConvert
> > MatConvert(J, MATAIJ, MAT_REUSE_MATRIX, & J);
> > where J is my Jacobian matrix.
> Seems to me this should fail because you didn't MatConvert this matrix
> yet. Anyway, you should use MAT_INITIAL_MATRIX and put the result in a
> new Mat.
> Cheers
