[petsc-users] Questions about MatConvert BAIJ to AIJ
Jed Brown jed at jedbrown.org
Wed Mar 18 14:48:54 CDT 2015
Chung-Kan Huang <ckhuangf at gmail.com> writes:
> Yes, I was suprised that I can still use MatSetValuesBlocked after I did
> MatConvert MATBAIJ to MATAIJ.
> Then I just found the mat type is still seqbaij which means the MatConvert
> didn't work.
> This is how I did MatConvert
> MatConvert(J, MATAIJ, MAT_REUSE_MATRIX, & J);
> where J is my Jacobian matrix.
Seems to me this should fail because you didn't MatConvert this matrix
yet.  Anyway, you should use MAT_INITIAL_MATRIX and put the result in a
new Mat.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150318/0f39d45a/attachment.pgp>
