[petsc-users] Questions about MatConvert BAIJ to AIJ
Wed Mar 18 14:24:40 CDT 2015
  Are you always using MatSetValuesBlocked()?
  Did you look at the three matrices (before passing to the solve), do they all have the exact same nonzero structure and entries?
  Barry
> On Mar 18, 2015, at 1:45 PM, Chung-Kan Huang <ckhuangf at gmail.com> wrote:
> So go back to my original question,
> I found the resuls look like
> MATBAIJ == MATBAIJ2MATAIJ != MATAIJ
> as I was expected to see
> MATBAIJ != MATBAIJ2MATAIJ == MATAIJ
> because I thought MATBAIJ2MATAIJ & MATAIJ should use the same ILU factorization.
> On Wed, Mar 18, 2015 at 1:33 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    As I think I said earlier: ILU will behave differently with BAIJ and AIJ format. With BAIJ it uses a point block factorization (doing an ILU treating each block in the matrix as a single point (and doing a dense factorization for the inverse) while AIJ ignores the block size and just uses a point ILU. So in general the convergence with BAIJ vs AIJ and ILU will be different; usually BAIJ will converge better but it need not.
>    Barry
> > On Mar 18, 2015, at 1:23 PM, Chung-Kan Huang <ckhuangf at gmail.com> wrote:
> > Sorry I didn't state my problem more accurate.  The entries in the input matrixes and vectors​ are correct -- they have right values and correct nonzero structure.
> > The KSP was setup so I can solve the lienar systems for an unsteady state convective problem.
> > I use KSPBCGS + PCILU and so far I only try sequential on a very small problem.
> > I wonder if blocked ilu is actually used in  MATBAIJ2MATAIJ case.
> > Thanks,
> Cheers
