[petsc-users] Use of KSPSetOperators
Chung-Kan Huang ckhuangf at gmail.com
Tue Mar 17 16:26:56 CDT 2015
I am a little confused about the statement in KSPSateOperators.
        KSP <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSP.html#KSP>/PCGetOperators
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGetOperators.html#PCGetOperators>(ksp/pc,&mat,&pmat);
is equivalent to
          set size, type, etc of mat and pmat
         MatCreate
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreate.html#MatCreate>(comm,&mat);
        MatCreate
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreate.html#MatCreate>(comm,&pmat);
        KSP <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSP.html#KSP>/PCSetOperators
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCSetOperators.html#PCSetOperators>(ksp/pc,mat,pmat);
        PetscObjectDereference
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscObjectDereference.html#PetscObjectDereference>((PetscObject
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscObject.html#PetscObject>)mat);
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscObject.html#PetscObject>)pmat);
In my case I want to construct preconditioner from P which will be
assembled differently from A.
So I only need to do
KSPSetOperators(ksp, A, P);
after A & P are created.
or do I need to also do
PCSetOperators(pc, A, P);
as well?
and what are those PetscObjectDereference
about?
I have tried doing only
and I saw the performance of linear solver changed and I got right answer
but I am not sure is if it was doing the thing I think it was doing.
And is it anyway to know if it is doing what I am asking?
Kan
*Cheers*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150317/e0e1e56b/attachment.html>
