[petsc-users] Use MatConvert
Barry Smith
bsmith at mcs.anl.gov
Tue Mar 17 12:43:20 CDT 2015
> On Mar 17, 2015, at 11:40 AM, Chung-Kan Huang <ckhuangf at gmail.com> wrote:
> Hi,
> I wonder what I did wrong when using MATConvert...
> MatCreate(* comm_, &J_);
> PetscInt * d_nnz = NULL;
> PetscInt * o_nnz = NULL;
> PetscMalloc(local_size * sizeof(PetscInt), & d_nnz);
> PetscMalloc(local_size * sizeof(PetscInt), & o_nnz);
> for (int i = 0; i < local_size; i++) {
> d_nnz[i] = d_nnz_v[i];
> o_nnz[i] = o_nnz_v[i];
> MatSetSizes(J_,
> local_size,
> local_size,
> PETSC_DECIDE,
> PETSC_DECIDE);
> MatSetBlockSize(J_, M_SIZE); // So MatSetValuesBlocked can be used
> MatSetType(J_, MATAIJ);
> if (comm_->Get_size() > 1) {
You don't need to have this if here; just call both MatMPIAIJSetPreallocation and MatSeqAIJSetPreallocation() and PETSc will use the correct one and ignore the other one automatically.
> // MPI
> MatMPIAIJSetPreallocation(J_,
> max_d_nz,
> d_nnz,
> max_o_nz,
> o_nnz);
> } else {
> // Seq
> MatSeqAIJSetPreallocation(J_,
> PETSC_DEFAULT,
> d_nnz);
> PetscFree(d_nnz);
> PetscFree(o_nnz);
> // Column oriented
> MatSetOption(J_, MAT_ROW_ORIENTED, PETSC_FALSE);
> // Test code to check if J_ has right structure
> preAssembeJ();
> <image.png>
> MatAssemblyBegin(J_, MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(J_, MAT_FINAL_ASSEMBLY);
> MatConvert(J_, MATBAIJ, MAT_REUSE_MATRIX, & J_);
I cannot understand what is wrong. Is it producing the wrong matrix? Please send the entire code so we can run it ourselves.
Barry
> MatZeroEntries(J_);
> preAssembeJ();
> <image.png>
> Thanks,
> Kan
> Cheers
