[petsc-users] [Fwd: Re: saving views as images]
Theler German Guillermo
gtheler at cites-gss.com
Thu Mar 12 12:49:36 CDT 2015
On Wed, 2015-03-11 at 13:47 -0500, Barry Smith wrote:
> Thanks for the suggestions and observations. I have made a new branch barry/improve-afterimage
Works like a charm! But note that the "reserved" line
in your definition of PetscAfterImageFormats in xinit.c:305 the
"reserved" follows mi previous e-mail, that was originally quoted from
libAfterImage's documentation. That line is a comment. I think it should
match the definitions that start at line 133 of the file import.c in
libAfterImage source
(https://github.com/sashavasko/afterstep-devel/blob/master/libAfterImage/import.c)
> that allows one to set the file format saved by passing it in the filename. On
Nice! Remember to include in the PETSc documentation the fact that
three-letter extension ".jpg" does not work and that the user should
pass ".jpeg" as extension.
> my Mac with the --download-afterimage only .Gif and .Jpeg formats are supported (by Afterimage) but that will depend on your install of Afterimage I guess (Png gives me the same error message you get).
My configure script complains about --download-afterimage:
gtheler at blinky:~/libs/petsc-afterimage$ ./configure
Configuring PETSc to compile on your
system
TESTING: alternateConfigureLibrary from
config.packages.Triangle(config/BuildSystem/config/package.py:640)
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
for details):
External package afterimage does not support --download-afterimage
The zlib error is raised in libpng12's in pngwutil.c:557 because a call
to zlib's deflateInit2 does not return Z_OK. I will investigate this
issue in more detail.
Thanks for your time
jeremy
Imprima este mensaje sólo si es absolutamente necesario.
Para imprimir, en lo posible utilice el papel de ambos lados.
El Grupo Sancor Seguros se compromete con el cuidado del medioambiente.
************AVISO DE CONFIDENCIALIDAD************
El Grupo Sancor Seguros comunica que:
Este mensaje y todos los archivos adjuntos a el son para uso exclusivo del destinatario y pueden contener información confidencial o propietaria, cuya divulgación es sancionada por ley. Si usted recibió este mensaje erróneamente, por favor notifíquenos respondiendo al remitente, borre el mensaje original y destruya las copias (impresas o grabadas en cualquier medio magnético) que pueda haber realizado del mismo. Todas las opiniones contenidas en este mail son propias del autor del mensaje. La publicación, uso, copia o impresión total o parcial de este mensaje o documentos adjuntos queda prohibida.
Disposición DNDP 10-2008. El titular de los datos personales tiene la facultad de ejercer el derecho de acceso a los mismos en forma gratuita a intervalos no inferiores a seis meses, salvo que acredite un interés legítimo al efecto conforme lo establecido en el artículo 14, inciso 3 de la Ley 25.326. La DIRECCIÓN NACIONAL DE PROTECCIÓN DE DATOS PERSONALES, Organo de Control de la Ley 25.326, tiene la atribución de atender las denuncias y reclamos que se interpongan con relación al incumplimiento de las normas sobre la protección de datos personales.
