[petsc-users] make check error
Manav Bhatia bhatiamanav at gmail.com
Thu Mar 12 10:46:11 CDT 2015
I got the code to work with a consistent combination of mpi and gcc compilers.
Thanks for your help!
-Manav
> On Mar 11, 2015, at 2:35 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Mar 11, 2015, at 1:50 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
>>> On Mar 11, 2015, at 1:47 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> Actually mumps is being used - so fortran is required [by mumps]
>>> The reason for the 'multiple' libgfortran messages is: openmpi is
>>> compiled with an older version of gcc/gfortran
>> You are right about openmpi being build with an older version of the compiler. I am trying to mix and match codes.
>   This is not a good idea. It is really really difficult for us to help you get things working when you have mixed and matched codes.
>  Barry
>>> [and I suspect its harmless - as the binaries are created]
>>> The primary issue to check: is this openmpi install functional - if so
>>> how do you run mpi binaries? Perhaps its a cluster - and have to go
>>> through a scheduler.. [i.e make check is perhaps inappropriate for
>>> this case]
>> This might be true. This is my first time working on this system, so I need to find out the details.
>>> Satish
>>> Python version:
>>> 2.4.2 (#1, Jan 10 2008, 17:43:47)
>>> [GCC 4.1.2 20070115 (prerelease) (SUSE Linux)]
>>> Executing: mpicc --version
>>> stdout:
>>> gcc (GCC) 4.8.3
>>> Executing: mpicc -show
>>> stdout: gcc -I/usr/local/mpi/x86_64/openmpi-1.4.2/include -pthread -L/usr/local/mpi/x86_64/openmpi-1.4.2/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
>>> Driving: /usr/local/gnu/gcc-4.8.3/bin/gfortran -o /tmp/petsc-X1bXQ9/config.compilers/conftest -v -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O /tmp/petsc-X1bXQ9/config.compilers/conftest.o -L/usr/local/mpi/x86_64/openmpi-1.4.2/lib -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/usr/local/s\
>>> erver/x86_64-SuSE10/gnu/gcc-4.8.3/lib/gcc -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib64 -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib -ldl -lmpi -lopen-rte -lopen-pal -lnsl -lutil -lgcc_s -lpthread -ldl -I/usr/local/mpi/x86_64/openmpi-1.4.2/include -pthread -I/usr/local/mpi/x86_64/openmpi-1.4.2/lib -L/usr/local/mpi/x86_64/openmpi-1.4.2/lib -lmpi_f90 -lmpi_f77 -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -l gfortran -lm -ldl -l gfortran -l m -shared-libgcc -specs=/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib64/libgfortran.spec
>>> /usr/local/gnu/gcc-4.8.3/binutils/bin/ld: warning: libgfortran.so.1, needed by /usr/local/mpi/x86_64/openmpi-1.4.2/lib/libmpi_f90.so, may conflict with libgfortran.so.3
>>> On Wed, 11 Mar 2015, Barry Smith wrote:
>>>> Since you are providing mpicc and mpicxx do not provide the --with-mpi-include= --with-mpi-lib=
>>>> I notice you have --with-fortran=0  if you do not want fortran than use --with-fc=0 and do not provide --FC and this may solve the gfortran issue
>>>> Barry
>>>>> On Mar 11, 2015, at 1:24 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
>>>>> I apologize for not sending these files along. Here they are for the two machines.
>>>>> Really appreciate your help.
>>>>> -Manav
>>>>>> On Mar 11, 2015, at 1:21 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>>> Lots of problems with your system but the biggest is that it appears you have two gfortran installs that interfere with each other. If you had followed the instructions and sent configure.log and make.log we could help you more.
>>>>>> Barry
>>>>>>> On Mar 11, 2015, at 1:12 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
>>>>>>> Greetings!
>>>>>>> I have come across the following error while running make check. I am not sure where to begin to sort this out. Any pointers would be greatly appreciated.
>>>>>>> Talon-login[114] bhatia$ make check
>>>>>>> gmake[1]: Entering directory `/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3'
>>>>>>> Running test examples to verify correct installation
>>>>>>> Using PETSC_DIR=/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3 and PETSC_ARCH=arch-linux2-cxx-opt
>>>>>>> gmake[2]: Entering directory `/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/src/snes/examples/tutorials'
>>>>>>> gmake[2]: Leaving directory `/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/src/snes/examples/tutorials'
>>>>>>> *******************Error detected during compile or link!*******************
>>>>>>> See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>>>> /cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/src/snes/examples/tutorials ex19
>>>>>>> gmake[3]: Entering directory `/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/src/snes/examples/tutorials'
>>>>>>> gmake[4]: Entering directory `/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/src/snes/examples/tutorials'
>>>>>>> gmake[4]: Leaving directory `/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/src/snes/examples/tutorials'
>>>>>>> mpicxx -o ex19.o -c -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O      -I/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/include -I/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/arch-linux2-cxx-opt/include -I/usr/local/openssl/x86_64/include -I/usr/local/mpi/x86_64/openmpi/include -I/usr/local/mpi/x86_64/openmpi-1.4.2/include    `pwd`/ex19.c
>>>>>>> mpicxx -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O   -o ex19  ex19.o -L/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/arch-linux2-cxx-opt/lib  -lpetsc -Wl,-rpath,/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/arch-linux2-cxx-opt/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lsuperlu_4.3 -lsuperlu_dist_3.3 -Wl,-rpath,/cavs/projects/sams/codes/raptor/lapack -L/cavs/projects/sams/codes/raptor/lapack -llapack -Wl,-rpath,/cavs/projects/sams/codes/raptor/blas -L/cavs/projects/sams/codes/raptor/blas -lblas -lparmetis -lmetis -lpthread -Wl,-rpath,/usr/local/openssl/x86_64/lib -L/usr/local/openssl/x86_64/lib -lssl -lcrypto -Wl,-rpath,/usr/local/mpi/x86_64/openmpi/lib -L/usr/local/mpi/x86_64/openmpi/lib -lmpi_cxx -lmpi -L/usr/local/mpi/x86_64/openmpi-1.4.2/lib -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib/gcc -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib64 -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -L/usr/local/mpi/x86_64/openmpi-1.4.2/lib -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib/gcc -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib64 -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib -ldl -lmpi -lopen-rte -lopen-pal -lnsl -lutil -lgcc_s -lpthread -ldl
>>>>>>> /usr/local/gnu/gcc-4.8.3/binutils/bin/ld: warning: libgfortran.so.1, needed by /usr/local/mpi/x86_64/openmpi/lib/libmpi_f90.so, may conflict with libgfortran.so.3
>>>>>>> /bin/rm -f ex19.o
>>>>>>> gmake[3]: Leaving directory `/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/src/snes/examples/tutorials'
>>>>>>> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
>>>>>>> libibverbs: Warning: RLIMIT_MEMLOCK is 32768 bytes.
>>>>>>> This will severely limit memory registrations.
>>>>>>> libibverbs: Warning: couldn't open config directory '/etc/libibverbs.d'.
>>>>>>> libibverbs: Warning: no userspace device-specific driver found for /sys/class/infiniband_verbs/uverbs0
>>>>>>> CMA: unable to open /dev/infiniband/rdma_cm
>>>>>>> [Talon-login:18281] *** Process received signal ***
>>>>>>> [Talon-login:18281] Signal: Segmentation fault (11)
>>>>>>> [Talon-login:18281] Signal code: Address not mapped (1)
>>>>>>> [Talon-login:18281] Failing at address: 0x100002990
>>>>>>> [Talon-login:18281] [ 0] /lib64/libpthread.so.0 [0x2b8e9cbc6c00]
>>>>>>> [Talon-login:18281] [ 1] /usr/ofed/lib64/libibverbs.so.1 [0x2b8e9fcad4ce]
>>>>>>> [Talon-login:18281] [ 2] /usr/ofed/lib64/libibverbs.so.1(ibv_get_device_list+0x9e) [0x2b8e9fcac49e]
>>>>>>> [Talon-login:18281] [ 3] /usr/local/mpi/x86_64/openmpi-1.4.2/lib/openmpi/mca_btl_openib.so [0x2b8e9fdbe15a]
>>>>>>> [Talon-login:18281] [ 4] /usr/local/mpi/x86_64/openmpi/lib/libmpi.so.0(mca_btl_base_select+0x156) [0x2b8e9d223166]
>>>>>>> [Talon-login:18281] [ 5] /usr/local/mpi/x86_64/openmpi-1.4.2/lib/openmpi/mca_bml_r2.so [0x2b8e9f997821]
>>>>>>> [Talon-login:18281] [ 6] /usr/local/mpi/x86_64/openmpi/lib/libmpi.so.0(mca_bml_base_init+0x72) [0x2b8e9d222972]
>>>>>>> [Talon-login:18281] [ 7] /usr/local/mpi/x86_64/openmpi-1.4.2/lib/openmpi/mca_pml_ob1.so [0x2b8e9f77fc8f]
>>>>>>> [Talon-login:18281] [ 8] /usr/local/mpi/x86_64/openmpi/lib/libmpi.so.0(mca_pml_base_select+0x383) [0x2b8e9d22c743]
>>>>>>> [Talon-login:18281] [ 9] /usr/local/mpi/x86_64/openmpi/lib/libmpi.so.0 [0x2b8e9d1f0050]
>>>>>>> [Talon-login:18281] [10] /usr/local/mpi/x86_64/openmpi/lib/libmpi.so.0(PMPI_Init_thread+0xc1) [0x2b8e9d20db41]
>>>>>>> [Talon-login:18281] [11] ./ex19(PetscInitialize+0x1bd) [0x4990fe]
>>>>>>> [Talon-login:18281] [12] ./ex19(main+0x2a) [0x48471e]
>>>>>>> [Talon-login:18281] [13] /lib64/libc.so.6(__libc_start_main+0xf4) [0x2b8e9e331164]
>>>>>>> [Talon-login:18281] [14] ./ex19 [0x482639]
>>>>>>> [Talon-login:18281] *** End of error message ***
>>>>>>> mpirun noticed that process rank 0 with PID 18281 on node Talon-login.HPC.MsState.Edu exited on signal 11 (Segmentation fault).
>>>>>>> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI processes
>>>>>>> [Talon-login:18286] *** Process received signal ***
>>>>>>> [Talon-login:18286] Signal: Segmentation fault (11)
>>>>>>> [Talon-login:18286] Signal code: Address not mapped (1)
>>>>>>> [Talon-login:18286] Failing at address: 0x100002990
>>>>>>> [Talon-login:18286] [ 0] /lib64/libpthread.so.0 [0x2acc0604ec00]
>>>>>>> [Talon-login:18286] [ 1] /usr/ofed/lib64/libibverbs.so.1 [0x2acc091354ce]
>>>>>>> [Talon-login:18286] [ 2] /usr/ofed/lib64/libibverbs.so.1(ibv_get_device_list+0x9e) [0x2acc0913449e]
>>>>>>> [Talon-login:18286] [ 3] /usr/local/mpi/x86_64/openmpi-1.4.2/lib/openmpi/mca_btl_openib.so [0x2acc0924615a]
>>>>>>> [Talon-login:18286] [ 4] /usr/local/mpi/x86_64/openmpi/lib/libmpi.so.0(mca_btl_base_select+0x156) [0x2acc066ab166]
>>>>>>> [Talon-login:18286] [ 5] /usr/local/mpi/x86_64/openmpi-1.4.2/lib/openmpi/mca_bml_r2.so [0x2acc08e1f821]
>>>>>>> [Talon-login:18286] [ 6] /usr/local/mpi/x86_64/openmpi/lib/libmpi.so.0(mca_bml_base_init+0x72) [0x2acc066aa972]
>>>>>>> [Talon-login:18286] [ 7] /usr/local/mpi/x86_64/openmpi-1.4.2/lib/openmpi/mca_pml_ob1.so [0x2acc08c07c8f]
>>>>>>> [Talon-login:18286] [ 8] /usr/local/mpi/x86_64/openmpi/lib/libmpi.so.0(mca_pml_base_select+0x383) [0x2acc066b4743]
>>>>>>> [Talon-login:18286] [ 9] /usr/local/mpi/x86_64/openmpi/lib/libmpi.so.0 [0x2acc06678050]
>>>>>>> [Talon-login:18286] [10] /usr/local/mpi/x86_64/openmpi/lib/libmpi.so.0(PMPI_Init_thread+0xc1) [0x2acc06695b41]
>>>>>>> [Talon-login:18286] [11] ./ex19(PetscInitialize+0x1bd) [0x4990fe]
>>>>>>> [Talon-login:18286] [12] ./ex19(main+0x2a) [0x48471e]
>>>>>>> [Talon-login:18286] [13] /lib64/libc.so.6(__libc_start_main+0xf4) [0x2acc077b9164]
>>>>>>> [Talon-login:18286] [14] ./ex19 [0x482639]
>>>>>>> [Talon-login:18286] *** End of error message ***
>>>>>>> mpirun noticed that process rank 0 with PID 18286 on node Talon-login.HPC.MsState.Edu exited on signal 11 (Segmentation fault).
>>>>>>> /cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/src/snes/examples/tutorials ex5f
>>>>>>> mpif90 -c  -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O   -I/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/include -I/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/arch-linux2-cxx-opt/include -I/usr/local/openssl/x86_64/include -I/usr/local/mpi/x86_64/openmpi/include -I/usr/local/mpi/x86_64/openmpi-1.4.2/include    -o ex5f.o ex5f.F
>>>>>>> mpif90 -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O   -o ex5f ex5f.o -L/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/arch-linux2-cxx-opt/lib  -lpetsc -Wl,-rpath,/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3/arch-linux2-cxx-opt/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lsuperlu_4.3 -lsuperlu_dist_3.3 -Wl,-rpath,/cavs/projects/sams/codes/raptor/lapack -L/cavs/projects/sams/codes/raptor/lapack -llapack -Wl,-rpath,/cavs/projects/sams/codes/raptor/blas -L/cavs/projects/sams/codes/raptor/blas -lblas -lparmetis -lmetis -lpthread -Wl,-rpath,/usr/local/openssl/x86_64/lib -L/usr/local/openssl/x86_64/lib -lssl -lcrypto -Wl,-rpath,/usr/local/mpi/x86_64/openmpi/lib -L/usr/local/mpi/x86_64/openmpi/lib -lmpi_cxx -lmpi -L/usr/local/mpi/x86_64/openmpi-1.4.2/lib -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib/gcc -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4..8.3/lib64 -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -L/usr/local/mpi/x86_64/openmpi-1.4.2/lib -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib/gcc -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib64 -L/usr/local/server/x86_64-SuSE10/gnu/gcc-4.8.3/lib -ldl -lmpi -lopen-rte -lopen-pal -lnsl -lutil -lgcc_s -lpthread -ldl
>>>>>>> /bin/rm -f ex5f.o
>>>>>>> Possible error running Fortran example src/snes/examples/tutorials/ex5f with 1 MPI process
>>>>>>> Program received signal SIGSEGV: Segmentation fault - invalid memory reference.
>>>>>>> Backtrace for this error:
>>>>>>> #0  0x2B6CD4A6F4D7
>>>>>>> #1  0x2B6CD4A6FADE
>>>>>>> #2  0x2B6CD5805E1F
>>>>>>> #3  0x2B6CD716F4CE
>>>>>>> #4  0x2B6CD716E49D
>>>>>>> #5  0x2B6CD7280159
>>>>>>> #6  0x2B6CD46E5165
>>>>>>> #7  0x2B6CD6E59820
>>>>>>> #8  0x2B6CD46E4971
>>>>>>> #9  0x2B6CD6C41C8E
>>>>>>> #10  0x2B6CD46EE742
>>>>>>> #11  0x2B6CD46B204F
>>>>>>> #12  0x2B6CD46CF99F
>>>>>>> #13  0x2B6CD494AA84
>>>>>>> #14  0x489A6D in petscinitialize_
>>>>>>> #15  0x487CEC in MAIN__ at ex5f.F:?
>>>>>>> mpirun noticed that process rank 0 with PID 18354 on node Talon-login.HPC.MsState.Edu exited on signal 11 (Segmentation fault).
>>>>>>> Completed test examples
>>>>>>> gmake[1]: Leaving directory `/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3'
>>>>>>> Now to evaluate the computer systems you plan use - do:
>>>>>>> make PETSC_DIR=/cavs/projects/sams/codes/raptor/petsc/petsc-3.5.3 PETSC_ARCH=arch-linux2-cxx-opt streams NPMAX=<number of MPI processes you intend to use>
>>>>>>> Talon-login[115] bhatia$
>>>>>>> Thanks,
>>>>>>> Manav
>>>>> <configure_shadow.log><configure_talon.log><make_shadow.log><make_talon.log>
