[petsc-users] Error with debug
Saurabh Chawdhary
saurabh.chawdhary at gmail.com
Mon Mar 9 11:25:46 CDT 2015
Sorry here is the Error trace I get on running on 1 processor:
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR:
or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
corruption errors
[0]PETSC ERROR: PetscMallocValidate: error detected at
PetscSignalHandlerDefault() line 149 in src/sys/error/signal.c
[0]PETSC ERROR: Memory at address 0x7fe4fdc6f010 is corrupted
[0]PETSC ERROR: Probably write past beginning or end of array
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Memory corruption!
[0]PETSC ERROR: !
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.4.5, Jun, 29, 2014
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ../IB-AMRS/test1 on a arch-linux2-c-debug named
aegean.safl.umn.edu by chaw0023 Mon Mar 9 11:24:50 2015
[0]PETSC ERROR: Libraries linked from
/home/chaw0023/software/aegean/debug/petsc-3.4.5/arch-linux2-c-debug/lib
[0]PETSC ERROR: Configure run at Thu Feb 19 12:22:29 2015
[0]PETSC ERROR: Configure options
--with-mpi-dir=/safl/software/aegean/openmpi/1.5.5/gcc/4.7.0-fix
--with-blas-lapack-dir=/safl/software/x86_64/acml/4.4.0/gfortran64
--download-hypre=yes --with-shared-libraries=0 --with-debugging=1
[0]PETSC ERROR:
[0]PETSC ERROR: PetscMallocValidate() line 137 in src/sys/memory/mtr.c
[0]PETSC ERROR: PetscSignalHandlerDefault() line 149 in
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 0.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
On Mon, Mar 9, 2015 at 10:55 AM, Jed Brown <jed at jedbrown.org> wrote:
> Saurabh Chawdhary <saurabh.chawdhary at gmail.com> writes:
> > Hi,
> > I used to work with petsc and running everything fine thus far. But then
> I
> > decided to run it with a debugger. To this end I re-installed petsc
> > --with-debugging=1. I can compile the code with this new petsc
> installation
> > but when I run it I get Segmentation fault error. Same code compiled with
> > the old without debug option runs perfectly fine.
> > Is something wrong with my new installation?
> Run in a debugger and send the stack trace.
सौरभ चौधरी
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150309/8552b140/attachment.html>
