[petsc-users] Sparse triangular solver
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Mar  8 18:26:01 CDT 2015
  PETSc provides sparse parallel LU (and Cholesky) factorizations and solves via the external packages SuperLU_Dist, MUMPS, and Pastix. You need to first configure PETSc to use one or more of those packages for example ./configure --download-superlu_dist --download-metis --download-parmetis.
  It is generally best to use the linear solvers via the PETSc KSP interface (even for direct solvers such as LU). So you create a KSP object, provide the matrix object and call KSPSolve(). You can control the solver used via the options database; to use the installed SuperLU_Dist you would use -pc_type lu -pc_factor_mat_solver_package superlu_dist
  The MatrixMarket format is no good for parallel computing so you must first convert the file from MatrixMarket format to the PETSc binary format (see http://www.mcs.anl.gov/petsc/documentation/faq.html#sparse-matrix-ascii-format ) and then  you can use MatLoad() to load the matrix in parallel and then pass it to the KSP solver. For example src/ksp/ksp/examples/tutorials/ex10.c does this.
  Barry
> On Mar 8, 2015, at 6:08 PM, Hoang-Vu Dang <dang.hvu at gmail.com> wrote:
> Hi,
> I would like to use petcs to perform parallel backward/forward substitution for sparse triangular matrices in a distributed memory cluster (with MPI).
> Could someone provide me some pointers on how to do this or whether petsc is good for this task ?
> I think there is MatSolve method, but unsure whether it supports good algorithm for sparse triangular matrices and how to provide an input in a MartrixMarket format / CSR format.
> Thank you
> Vu
