[petsc-users] log_summary MPI
Justin Chang jchang27 at uh.edu
Fri Mar 6 12:56:52 CST 2015
Matt, thank you for the response. One more question, is there a way to
output only the MPI messages and MPI message lengths? I don't want to print
everything when I do -log_summary, so are there any command line options
that do this? I can't seem to find anything in the manual that discusses
this.
On Fri, Mar 6, 2015 at 9:10 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Mar 5, 2015 at 6:12 PM, Justin Chang <jchang27 at uh.edu> wrote:
>> Hi all,
>> I apologize if these may be simple questions that could be found
>> somewhere. In the log_summary profiling, I have a few questions about the
>> MPI messages/MPI message lengths metrics:
>> 1) For MPI messages, does the value under Max correspond to the maximum
>> number of messages a single processor passes?
> Yes.
>> 2) What are the units of MPI message lengths? Is it in bytes?
> Yes, returned by PetscMPITypeSize().
>> 3) What does MPI message lengths refer to exactly? Like, does it refer to
>> the max/min/average size per sent/received message or does it refer to the
>> cumulative size that a single processor sends/receives?
> Cumulative, see
> https://bitbucket.org/petsc/petsc/src/d8151eeaff97562eb317e17b7b0cecab16831f69/include/petsclog.h?at=master#cl-343
>   Thanks,
>      Matt
>> Thanks
>> Justin Chang
>> PhD Candidate, Civil Engineering - Computational Sciences
>> University of Houston, Department of Civil and Environmental Engineering
>> Houston, TX 77004
>> (512) 963-3262
> experiments lead.
> -- Norbert Wiener
Justin Chang
Houston, TX 77004
(512) 963-3262
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150306/29134dc3/attachment.html>
