[petsc-users] Multigrid preconditioning of entire linear systems for discretized coupled multiphysics problems
    Fabian Gabel
    gabel.fabian at gmail.com
    Thu Mar  5 15:12:16 CST 2015
On Di, 2015-03-03 at 13:02 -0600, Barry Smith wrote:
> > On Mar 2, 2015, at 9:19 PM, Fabian Gabel <gabel.fabian at gmail.com> wrote:
> > On Mo, 2015-03-02 at 19:43 -0600, Barry Smith wrote:
> >>  Do you really want tolerances:  relative=1e-90, absolute=1.10423, divergence=10000? That is an absolute tolerance of 1.1? Normally that would be huge.
> > I started using atol as convergence criterion with -ksp_norm_type
> > unpreconditioned. The value of atol gets updated every outer iteration.
>    What is the "outer iteration" and why does it exist?
I used the term "outer iteration" as in Ferziger/Peric "Computational
Methods for Fluid Dynamics":
"... there are two levels of iterations: inner iterations, within which
the linear equations are solved, and outer iterations, that deal with
the non-linearity and coupling of the equations."
I chose the Picard-Iteration approach to linearize the non-linear terms
of the Navier-Stokes equations. The solution process is as follows:
1) Update matrix coefficients for the linear system for (u,v,w,p)
2) Calculate the norm of the initial residual r^(n):=||b - Ax^(n) ||_2
3) if (r^(n)/r(0) <= 1-e8) GOTO 7)
4) Calculate atol = 0.1 * r^(n)
5) Call KSPSetTolerances with rtol=1e-90 and atol as above and solve the
coupled linear system for (u,v,w,p)
6) GOTO 1)
7) END
With an absolute tolerance for the norm of the unpreconditioned residual
I feel like I have control over the convergence of the picard iteration.
Using rtol for the norm of the preconditioned residual did not always
achieve convergence.
> >>  You can provide your matrix with a block size that GAMG will use with MatSetBlockSize().
> > I think something went wrong. Setting the block size to 4 and solving
> > for (u,v,w,p) the convergence degraded significantly. I attached the
> > results for a smaller test case that shows the increase of the number of
> > needed inner iterations when setting the block size via
> > MatSetBlockSize().
>   This is possible.
Ok, so this concludes the experiments with out-of-the-box GAMG for the
fully coupled Navier-Stokes System? Why would the GAMG not perform well
on the linear system resulting from my discretization? What is the
difference between the algebraic multigrid implemented in PETSc and the
method used in the paper [1] I mentioned?
I am still looking for a scalable solver configuration. So far ILU with
various levels of fill has the best single process performance, but
scalability could be better. I have been experimenting with different
PCFIELDSPLIT configurations but the best configuration so far does not
outperform ILU preconditioning.
Fabian
[1] http://dx.doi.org/10.1016/j.jcp.2008.08.027
>   Barry
> >>  I would use coupledsolve_mg_coarse_sub_pc_type lu   it is weird that it is using SOR for 27 points.
> >> So you must have provided a null space since it printed "has attached null space"
> > The system has indeed a one dimensional null space (from the pressure
> > equation with Neumann boundary conditions). But now that you mentioned
> > it: It seems that the outer GMRES doesn't notice that the matrix has an
> > attached nullspace. Replacing
> > 	CALL MatSetNullSpace(CMAT,NULLSP,IERR)
> > with
> > 	CALL KSPSetNullSpace(KRYLOV,NULLSP,IERR)
> > solves this. What is wrong with using MatSetNullSpace?
> > Fabian
> >>  Barry
> >>> On Mar 2, 2015, at 6:39 PM, Fabian Gabel <gabel.fabian at gmail.com> wrote:
> >>> On Mo, 2015-03-02 at 16:29 -0700, Jed Brown wrote:
> >>>> Fabian Gabel <gabel.fabian at gmail.com> writes:
> >>>>> Dear PETSc Team,
> >>>>> I came across the following paragraph in your publication "Composable
> >>>>> Linear Solvers for Multiphysics" (2012):
> >>>>> "Rather than splitting the matrix into large blocks and
> >>>>> forming a preconditioner from solvers (for example, multi-
> >>>>> grid) on each block, one can perform multigrid on the entire
> >>>>> system, basing the smoother on solves coming from the tiny
> >>>>> blocks coupling the degrees of freedom at a single point (or
> >>>>> small number of points). This approach is also handled in
> >>>>> PETSc, but we will not elaborate on it here."
> >>>>> How would I use a multigrid preconditioner (GAMG)
> >>>> The heuristics in GAMG are not appropriate for indefinite/saddle-point
> >>>> systems such as arise from Navier-Stokes.  You can use geometric
> >>>> multigrid and use the fieldsplit techniques described in the paper as a
> >>>> smoother, for example.
> >>> I sadly don't have a solid background on multigrid methods, but as
> >>> mentioned in a previous thread
> >>> http://lists.mcs.anl.gov/pipermail/petsc-users/2015-February/024219.html
> >>> AMG has apparently been used (successfully?) for fully-coupled
> >>> finite-volume discretizations of Navier-Stokes:
> >>> http://dx.doi.org/10.1080/10407790.2014.894448
> >>> I was hoping to achieve something similar with the right configuration
> >>> of the PETSc preconditioners. So far I have only been using GAMG in a
> >>> straightforward manner, without providing any details on the structure
> >>> of the linear system. I attached the output of a test run with GAMG.
> >>>>> from PETSc on linear systems of the form (after reordering the
> >>>>> variables):
> >>>>> [A_uu   0     0   A_up  A_uT]
> >>>>> [0    A_vv    0   A_vp  A_vT]
> >>>>> [0      0   A_ww  A_up  A_wT]
> >>>>> [A_pu A_pv  A_pw  A_pp   0  ]
> >>>>> [A_Tu A_Tv  A_Tw  A_Tp  A_TT]
> >>>>> where each of the block matrices A_ij, with i,j in {u,v,w,p,T}, results
> >>>>> directly from a FVM discretization of the incompressible Navier-Stokes
> >>>>> equations and the temperature equation. The fifth row and column are
> >>>>> optional, depending on the method I choose to couple the temperature.
> >>>>> The Matrix is stored as one AIJ Matrix.
> >>>>> Regards,
> >>>>> Fabian Gabel
> >>> <cpld_0128.out.578677>
> > <log.blocksize4><log.txt>
