[petsc-users] Question about GAMG and memory use
    Randall Mackie
    rlmackie862 at gmail.com
    Thu Mar  5 12:07:56 CST 2015
> On Mar 4, 2015, at 7:30 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Mar 4, 2015, at 7:45 PM, Randall Mackie <rlmackie862 at gmail.com> wrote:
>> In my application, I am repeatedly calling KSPSolve with the following options:
>> -ksp_type gmres \
>> -pc_type gamg \
>> -pc_gamg_type agg \
>> -pc_gamg_agg_nsmooths 1\
>> each call is after the matrix and right hand side have been updated.
>> This works well in the sense that it solves the system in a reasonable number of steps, however, I have noticed that the memory footprint of the application increases by about 500 Mbytes after each call to KSPSolve (this is a big problem), and after several calls, I've maxed out the memory.
>> Is this expected behavior?
>  No
>> I've combed through my code looking to make sure I don't have any memory leaks, and so far I haven't found any (doesn't mean there are not there).
>> However, when I use another PC, like jacobi, just to compare, I don't see this memory issue, or if I comment out that call to KSPSolve (there is a lot of other stuff going on in the code besides this call), I don't see this issue.
>> I've tried to destroy the KSP after each solve and recreate it each time, but there still seems to be some memory getting added.
>   Run your program for a few solves with the command line option -malloc and after each call call to KSPSolve() put in a call to PetscMallocDump(). Take a look at the output and email it to us (this is best done with one process if you can; does the memory problem happen with 1 MPI process?).
Hi Barry,
When I run with 1 MPI process, I get this error message:
0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Arguments are incompatible
[0]PETSC ERROR: MatMatMult requires A, mpiaij, to be compatible with B, seqaij
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[0]PETSC ERROR: Configure options PETSC_DIR=/home/rmackie/PETSc/petsc-3.5.3 PETSC_ARCH=linux-gfortran-debug --with-scalar-type=complex --with-debugging=1 --with-fortran=1 --download-mpich
[0]PETSC ERROR: #1 MatMatMult() line 8710 in /home/rmackie/PETSc/petsc-3.5.3/src/mat/interface/matrix.c
[0]PETSC ERROR: #2 PCGAMGOptprol_AGG() line 1328 in /home/rmackie/PETSc/petsc-3.5.3/src/ksp/pc/impls/gamg/agg.c
[0]PETSC ERROR: #3 PCSetUp_GAMG() line 606 in /home/rmackie/PETSc/petsc-3.5.3/src/ksp/pc/impls/gamg/gamg.c
[0]PETSC ERROR: #4 PCSetUp() line 902 in /home/rmackie/PETSc/petsc-3.5.3/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #5 KSPSetUp() line 306 in /home/rmackie/PETSc/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #6 KSPSolve() line 418 in /home/rmackie/PETSc/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
Randy
>   Barry
>> I've tried to distill this down to a smaller problem and test program, but so far I have been unsuccessful.
>> Is there a way to completely release the memory associated with the GAMG preconditioner after a call to KSPSolve?
>> Any other suggestions for tracking this down? I've run out of ideas.
>> Thanks in advance,
>> Randy
