[petsc-users] near null space redundant
Matthew Knepley
knepley at gmail.com
Thu Mar 5 09:18:20 CST 2015
On Thu, Mar 5, 2015 at 5:01 AM, anton <popov at uni-mainz.de> wrote:
> Hi,
> Does the near-null-space get attached to the internal ksp object of
> redundant preconditioner, or a user has to scatter and attach it manually?
> If so, what would be a suggested way to do that?
Its not there, but would be easy to put in. I would either
a) Open an issue with the Bitbucket tracker, and someone will get to it
or
b) Code it up in a pull request
I think it would only be a few lines in PCSetUp_Redundant(). You check
whether the pc->mat has
an attached near null space, and then use the VecScatters above to map the
vectors, and carry
over the flag for constant null space.
Matt
> Thanks,
> Anton
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150305/c7317d6d/attachment.html>
