[petsc-users] petsc-dev and Fortran include files
Tabrez Ali stali at geology.wisc.edu
Sun Mar 1 14:05:57 CST 2015
Hello again
This is probably not directly related to petsc but what is the simplest
way to handle the change in the path of the include files (in petsc-dev)
while using Fortran?
I guess I can do the following:
#include <petscversion.h>
#if (PETSC_VERSION_RELEASE==0)
#include <petsc-finclude/petsc.h90>
#else
#include <finclude/petsc.h90>
#endif
but then I have to repeat it a number of times in each
module/subroutine. Is there a simpler way? I am not sure if I can use a
preprocessor variable in the include directive.
T
