[petsc-users] DMDA with dof=4, multigrid solver
Sun, Hui hus003 at ucsd.edu
Sun Mar 1 10:09:12 CST 2015
Hi Matt, I don't think what you said concerning using -pc_mg_galerkin to have it projected is what I'm looking for. What I try to do is the following:
I already have ComputeRHS and ComputeMatrix, and hence:
    ierr = KSPSetComputeRHS(ksp,ComputeRHS,NULL);CHKERRQ(ierr);
    ierr = KSPSetComputeOperators(ksp,ComputeMatrix,NULL);CHKERRQ(ierr);
    ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
    ierr = KSPSolve(ksp,NULL,NULL);CHKERRQ(ierr);
Now I have a vector v, let's say:
ierr = KSPGetSolution(ksp,&v);CHKERRQ(ierr);
After that, I want so set v to be my rhs, and solve the new system. It doesn't seem that something like this would work:
     ierr = KSPSolve(ksp,&x,&x);CHKERRQ(ierr);
So how do I set x to the rhs? It does not seem to me that -pc_mg_galerkin would set x as the rhs of the system.
Sent: Sunday, March 01, 2015 6:02 AM
To: Sun, Hui
Cc: Barry Smith; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] DMDA with dof=4, multigrid solver
On Sun, Mar 1, 2015 at 12:30 AM, Sun, Hui <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> wrote:
Thank you Barry. I have yet two more questions:
1) If I have a DMDA and I use KSPSetComputeOperators and KSPSetComputeRHS to set up matrices and rhs, and I use geometric mg, what if I want to change my rhs many times? Should I write many KSPSetComputeRHS, and register them with ksp? Or is there a simple way to just register the rhs with ksp as a vector?
If you just give a vector, you could use -pc_mg_galerkin to have it projected. Same with the matrix.
2) How do I create a Mat, whose cols follow the DMDA parallelization, and whose rows are serial?
Sparse matrices are always divided by rows across processors.
    Matt
By the way, I've figured out and fixed the bugs in my code concerning using mg with DMDA having 4 dof. It has to do with the interpolations. Now I can see mg works well with 4 dof DMDA.
Best,
Hui
From: Barry Smith [bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>]
Sent: Saturday, February 28, 2015 9:35 AM
To: Sun, Hui
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
> On Feb 27, 2015, at 7:25 PM, Sun, Hui <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> wrote:
> Thank you Barry. Another question: I observe that in those ksp examples, whenever multigrid is used, DMDA is also used, besides, KSPSetComputeOperators and KSPSetComputeRHS are also used.
> Is it true that
> 1) Only DMDA can use mg?
   No this is not true
> 2) We have to set up matrices and rhs using KSPSetComputeOperators  and KSPSetComputeRHS?
   No you do not have to
> We cannot create a matrix and add it to KSP if we want to use mg?
    Yes you can.
   There are many many variants of multigrid one can do with PETSc; we don't have the time to have examples of all the possibilities.
More details
   Because DMDA provides structured grids with easy interpolation between levels and it is easy for users to write Jacobians we have many examples that use the DMDA. However, so long as YOU (or something) can provide interpolation between the multigrid levels you can use multigrid. For example PCGAMG uses algebraic multigrid to generate the interpolations. If you have your own interpolations you can provide them with PCMGSetInterpolation() (when you use PCMG with DMDA PETSc essentially handles those details automatically for you).
   Normally with geometric multigrid one discretizes the operator on each level of the grid. Thus the user has to provide several matrices (one for each level). KSPSetComputeOperators() is ONE way that the user can provide them. You can also provide them by call PCMGetSmoother(pc,level,&ksp) and then call KSPSetOperators(ksp,...) for each of the levels (KSPSetComputeOperators() essentially does the book keeping for you).
    As I said in 2 normally multigrid requires you to provide a discretized operator at each level. But with Galerkin coarse grids (which is what algebraic multigrid users and can also be used by geometric multigrid) the user does not provide coarser grid operators instead the code computes them automatically from the formula R*A*P where R is the restriction operator used in multigrid and P is the interpolation operator (usually the transpose of P).
   If you are looking for a simple automatic multigrid then you want to use PCGAMG in PETSc, it does algebraic multigrid and doesn't require you provide interpolations or coarser operators. However algebraic multigrid doesn't work for all problems; though it does work for many. Try it with -pc_type gamg
  Barry
> Best,
> Hui
> Sent: Friday, February 27, 2015 5:11 PM
> To: Sun, Hui
>> On Feb 27, 2015, at 6:36 PM, Sun, Hui <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> wrote:
>> I'm trying to work on 4 Poisson's equations defined on a DMDA grid, Hence the parameter dof in DMDACreate3d should be 4, and I've set stencil width to be 4, and stencil type to be star.
>  Use a stencil width of 1, not 4. The stencil width is defined in terms of dof.
>> If I run the code with -pc_type ilu and -ksp_type gmres, it works alright.
>> However, if I run with pc_type mg, it gives me an error saying that when it is doing MatSetValues, the argument is out of range, and there is a new nonzero at (60,64) in the matrix. However, that new nonzero is expected to be there, the row number 60 corresponds to i=15 and c=0 in x direction, and the column number 64 corresponds to i=16 and c=0 in x direction. So they are next to each other, and the star stencil with width 1 should include that. I have also checked with the memory allocations, and I'm found no problem.
>> So I'm wondering if there is any problem of using multigrid on a DMDA with dof greater than 1?
>  No it handles dof > 1 fine.
>  Send your code.
>  Barry
>> Thank you!
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150301/73b0eabe/attachment.html>
