[petsc-users] PetscLogStage functions not working in fortran
Matthew Knepley
knepley at gmail.com
Sun Mar 1 08:15:27 CST 2015
Don't you need a 'call' first?
Matt
On Sun, Mar 1, 2015 at 8:09 AM, luc berger-vergiat <lb2653 at columbia.edu>
wrote:
> I get the following:
> nm /home/luc/research/petsc-3.5.2/arch-opt/lib/libpetsc.a | grep -i
> PetscLogStageRegister
> 0000000000000338 T PetscLogStageRegister
> 00000000000004ba T petsclogstageregister_
> U PetscLogStageRegister
> On Mar 1, 2015, at 9:06 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Mar 1, 2015 at 12:28 AM, Luc Berger-Vergiat <lb2653 at columbia.edu>
> wrote:
>> Hi all,
>> I am trying to fine gain a little my program profiling but cannot get
>> PetscLogStageRegiset, PetscLogStagePush and PetscLogStagePop to work in my
>> Fortran code.
>> Here is my fortran subroutine:
> They are certainly there:
> https://bitbucket.org/petsc/petsc/src/5620d6dc8304f23d8d30f97758f32d1dd71aa0ff/src/sys/logging/ftn-custom/zplogf.c?at=master#cl-118
> What do you get for
> nm $PETSC_ARCH/lib/libpetsc.a | grep -i PetscLogStageRegister
> Matt
>> subroutine SetPetscStage(StageNum)
>> implicit none
>> # include "finclude/petsc.h"
>> integer StageNum
>> character StageName*5
>> PetscErrorCode ierr
>> PetscInt Stage
>> if(StageNum.eq.1) then
>> Stage = 1
>> PetscLogStageRegister("Jacobian and residual assembly",
>> & Stage,ierr)
>> PetscLogStagePush(Stage,ierr)
>> elseif(StageNum.eq.11) then
>> PetscLogStagePop()
>> endif
>> end
>> I get the following compiler error when I try to make my program:
>> SetPetscStage.F:14.9:
>> 1
>> Error: Unclassifiable statement at (1)
>> SetPetscStage.F:16.9:
>> 1
>> SetPetscStage.F:18.9:
>> PetscLogStagePop()
>> 1
>> Any idea on what is be happening?
>> Best,
>> Luc
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150301/51dedd9b/attachment.html>
