[petsc-users] preprocessing problem
    Satish Balay
    balay at mcs.anl.gov
    Tue Jun 30 20:15:40 CDT 2015
most fortran examples wont work with --with-fortran-datatypes=1 option.
Satish
On Tue, 30 Jun 2015, W. Miah wrote:
> Hi Satish,
> I managed to fix it by using the flag --with-fortran-interfaces=1 and
> removed --with-fortran-datatypes=1.
> Regards,
> Wadud.
> On 30 June 2015 at 23:54, W. Miah <wadud.miah at gmail.com> wrote:
> > Hi again Satish,
> > When I use the supplied makefile, I get the following error:
> > [hamilton1 petsc-examples]$ make ex2f
> > /usr/local/intel/ics_2013/impi/4.1.0.024/intel64/bin/mpif90 -c  -fPIC
> > -Wall -Wno-unused-variable -ffree-line-length-0 -O
> > -I/home/fcwm/petsc-3.6.0/include -I/home/fcwm/petsc-3.6.0/include
> > -I/home/fcwm/hypre-2.10.0b/include
> > -I/usr/local/intel/ics_2013/impi/4.1.0.024/intel64/include
> > -I/usr/local/intel/ics_2013/impi/4.1.0.024/intel64/include    -o
> > ex2f.o ex2f.F
> > ex2f.F:48: error: finclude/petscsys.h: No such file or directory
> > ex2f.F:49: error: finclude/petscvec.h: No such file or directory
> > ex2f.F:50: error: finclude/petscmat.h: No such file or directory
> > ex2f.F:51: error: finclude/petscpc.h: No such file or directory
> > ex2f.F:52: error: finclude/petscksp.h: No such file or directory
> > It obviously cannot find the Fortran header files. When I include the
> > path to the Fortran header files, it still complains:
> > -I/home/fcwm/petsc-3.6.0/include/petsc
> > ex2f.o ex2f.F
> > Warning: Nonconforming tab character in column 3 of line 1180
> > Warning: Nonconforming tab character in column 3 of line 1201
> > Warning: Nonconforming tab character in column 3 of line 1209
> > Warning: Nonconforming tab character in column 3 of line 3483
> > Warning: Nonconforming tab character in column 3 of line 3504
> > Warning: Nonconforming tab character in column 3 of line 3512
> > Warning: Nonconforming tab character in column 3 of line 4578
> > Warning: Nonconforming tab character in column 3 of line 4599
> > Warning: Nonconforming tab character in column 3 of line 4607
> > ex2f.F:82.6:
> >       Vec        x,b,u
> >       1
> > Error: Unclassifiable statement at (1)
> > ex2f.F:83.6:
> > I think I need to tell the Fortran compiler to use the C preprocessor
> > instead of the Fortran preprocessor.
> > Regards,
> > Wadud.
> > On 30 June 2015 at 23:33, W. Miah <wadud.miah at gmail.com> wrote:
> >> Hi Satish,
> >> Thanks for the Makefile.
> >> Regards,
> >> Wadud.
> >> On 30 June 2015 at 23:20, Satish Balay <balay at mcs.anl.gov> wrote:
> >>> Where did you grab this example from? the 'makefile' should be in the
> >>> same location.
> >>> For eg: if you grabbed src/ksp/ksp/examples/tutorials/ex2f.F - then you would use:
> >>> http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/makefile
> >>> The users manual has a section explaining the format.
> >>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manual.pdf#subsection.16.2.1
> >>> Satish
> >>>> Hi Satish,
> >>>> I can't find the Makefile that came with it. I'll have a trawl through
> >>>> the petsc download again, but if you could give me the compilation
> >>>> line that would be appreciated.
> >>>> Best regards,
> >>>> Wadud.
> >>>> >> Hi,
> >>>> >> This is probably a simple mistake, but I am getting the following
> >>>> >> error when trying to compile a Fortran PETSc example:
> >>>> >> [host petsc-examples]$ mpiifort -c -I/home/fcwm/petsc-3.6.0/include
> >>>> >> -I/home/fcwm/petsc-3.6.0/include/petsc ex2f.F
> >>>> >> ex2f.F(82): error #5082: Syntax error, found ',' when expecting one
> >>>> >> of: ( % [ : . = =>
> >>>> >>       Vec        x,b,u
> >>>> >> Any help will be greatly appreciated. Thanks in advance.
> >>>> > Are you not using the correspoding makefile that came with this example?
> >>>> > Satish
> >> email:   wadud.miah at gmail.com
> >> mobile: 07905 755604
> >> gnupg: 2E29 B22F
> > gnupg: 2E29 B22F
