[petsc-users] periodic boundary condition does not work after upgrading from 3.5.1 to 3.6.0
    Xiao, Jianjun (IKET)
    jianjun.xiao at kit.edu
    Tue Jun 30 07:10:14 CDT 2015
I am running a case with periodic boundary condition. It worked fine with PETSc 3.5.1. When PETSc was upgraded to 3.6.0, I got the error below.
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: Available only for boundary none or with parallism in y direction
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.6.0, Jun, 09, 2015
[0]PETSC ERROR: #295 DMLocalToGlobalBegin_DA() line 54 in /home/xiao/Local/petsc-3.6.0-debug/src/dm/impls/da/dagtol.c
[0]PETSC ERROR: #296 DMLocalToGlobalBegin() line 1944 in /home/xiao/Local/petsc-3.6.0-debug/src/dm/interface/dm.c
I have periodic boundary condition in y direction, and I used INSERT_VALUES in DMLocalToGlobal.
        CALL DMLocalToGlobalBegin(da_dof1,wb0_gfpp_loc,INSERT_VALUES,wb0_gfpp,ierr)
        CALL DMLocalToGlobalEnd(da_dof1,wb0_gfpp_loc,INSERT_VALUES,wb0_gfpp,ierr)
Please let me know if you need more information. Thanks in advance.
Best regards
Jianjun
