[petsc-users] TSSolve problems
Li, Xinya
Xinya.Li at pnnl.gov
Mon Jun 29 13:35:43 CDT 2015
Yes. it is C++.
I attached the major routines for TSSolve.
Thanks
Xinya
-----Original Message-----
Sent: Monday, June 29, 2015 11:27 AM
To: Li, Xinya
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] TSSolve problems
Is your code C++?
count time percent time
TSStep 600 3.1174e+02 100
TSFunctionEval 2937 1.4288e+02 46
TSJacobianEval 1737 1.3074e+02 42
KSPSolve 1737 3.5144e+01 11
Ok I pulled out the important time from the table. 46 percent of the time is in your function evaluation, 42 percent in the Jacobian evaluation and 11 percent in the linear solve.
The only way to improve the time significantly is by speeding up the function and Jacobian computations. What is happening in those routines, can you email them?
Barry
> On Jun 29, 2015, at 11:57 AM, Li, Xinya <Xinya.Li at pnnl.gov> wrote:
> Barry,
> Here is the new output without debugging.
> Thank you.
> Xinya
> From: Barry Smith [mailto:bsmith at mcs.anl.gov]
> Sent: Friday, June 26, 2015 12:04 PM
> To: Li, Xinya
> # WARNING!!! #
> # This code was compiled with a debugging option, #
> # To get timing results run ./configure #
> # using --with-debugging=no, the performance will #
> # be generally two or three times faster. #
> First you need to configure PETSc again without all the debugging. So do, for example,
> export PETSC=arch-opt
> ./configure --with-cc=gcc --with-fc=gfortran --with-cxx=g++ --with-scalar-type=complex --with-clanguage=C++ --with-cxx-dialect=C++11 --download-mpich --download-superlu_dist --download-mumps --download-scalapack --download-parmetis --download-metis --download-elemental make all test
> then recompile and rerun your example again with -log_summary and send the output.
> Note that you should not pass --download-fblaslapack nor the fortran kernel stuff.
> Barry
>> On Jun 26, 2015, at 12:16 PM, Li, Xinya <Xinya.Li at pnnl.gov> wrote:
>> Barry,
>> Thank you for your response.
>> Attached is the output. SNESSolve was taking most of the time.
>> Xinya
>> Sent: Thursday, June 25, 2015 5:47 PM
>> To: Li, Xinya
>> Run with -ts_view -log_summary and send the output. This will tell the current solvers and where the time is being spent.
>> Barry
>>> On Jun 25, 2015, at 6:37 PM, Li, Xinya <Xinya.Li at pnnl.gov> wrote:
>>> Dear Sir,
>>> I am using the ts solver to solve a set of ODE and DAE. The Jacobian matrix is a 1152 *1152 sparse complex matrix.
>>> Each TSStep in TSSolve is taking nearly 1 second. Thus, I need to improve the speed of TSSolve.
>>> Which parts should be taking into account to accelerate TSSolve?
>>> Thank you very much.
>>> Regards
>>> __________________________________________________
>>> Xinya Li
>>> Scientist
>>> EED/Hydrology
>>> Pacific Northwest National Laboratory
>>> 902 Battelle Boulevard
>>> P.O. Box 999, MSIN K9-33
>>> Richland, WA 99352 USA
>>> Tel: 509-372-6248
>>> Fax: 509-372-6089
>>> Xinya.Li at pnl.gov
>> <288g1081b_short.log>
> <d288gen.log>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150629/1aa1fe8c/attachment-0001.ksh>
