[petsc-users] TSSolve problems
Li, Xinya Xinya.Li at pnnl.gov
Mon Jun 29 11:57:56 CDT 2015
Barry,
Here is the new output without debugging.
Thank you.
Xinya
-----Original Message-----
Sent: Friday, June 26, 2015 12:04 PM
To: Li, Xinya
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] TSSolve problems
      #                          WARNING!!!                    #
      #   This code was compiled with a debugging option,      #
      #   To get timing results run ./configure                #
      #   using --with-debugging=no, the performance will      #
      #   be generally two or three times faster.              #
First you need to configure PETSc again without all the debugging. So do, for example,
export PETSC=arch-opt
./configure --with-cc=gcc --with-fc=gfortran --with-cxx=g++ --with-scalar-type=complex --with-clanguage=C++ --with-cxx-dialect=C++11  --download-mpich --download-superlu_dist --download-mumps --download-scalapack --download-parmetis --download-metis --download-elemental make all test
then recompile and rerun your example again with -log_summary and send the output.
Note that you should not pass --download-fblaslapack nor the fortran kernel stuff.
  Barry
> On Jun 26, 2015, at 12:16 PM, Li, Xinya <Xinya.Li at pnnl.gov> wrote:
> Barry,
> Thank you for your response.
> Attached is the output. SNESSolve was taking most of the time.
> Xinya
> From: Barry Smith [mailto:bsmith at mcs.anl.gov]
> Sent: Thursday, June 25, 2015 5:47 PM
> To: Li, Xinya
>  Run with -ts_view -log_summary and send the output. This will tell the current solvers and where the time is being spent.
>  Barry
>> On Jun 25, 2015, at 6:37 PM, Li, Xinya <Xinya.Li at pnnl.gov> wrote:
>> Dear Sir,
>> I am using the ts solver to solve a set of ODE and DAE. The Jacobian matrix is a 1152 *1152 sparse complex matrix.
>> Each TSStep in TSSolve is taking nearly 1 second. Thus, I need  to improve the speed of TSSolve.
>> Which parts should be taking into account to accelerate TSSolve?
>> Thank you very much.
>> Regards
>> __________________________________________________
>> Xinya Li
>> Scientist
>> EED/Hydrology
>> Pacific Northwest National Laboratory
>> 902 Battelle Boulevard
>> P.O. Box 999, MSIN K9-33
>> Richland, WA  99352 USA
>> Tel:  509-372-6248
>> Fax: 509-372-6089
>> Xinya.Li at pnl.gov
> <288g1081b_short.log>
Desc: d288gen.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150629/94ab8fea/attachment.obj>
