[petsc-users] jacobians for multicomponent problems
Matthew Knepley
knepley at gmail.com
Wed Jun 24 05:17:48 CDT 2015
On Wed, Jun 24, 2015 at 2:39 AM, domenico lahaye <domenico_lahaye at yahoo.com>
wrote:
> Would the same work for non-structured problems, for instance for power
> flow equations?
Yes, PetscSection knows about components for fields, and this carries
through to the DMNetwork setup.
It will, for instance, use block matrix formats if the block size is
constant.
Matt
> Thx. Domenico Lahaye.
> *From:* Matthew Knepley <knepley at gmail.com>
> *To:* Gideon Simpson <gideon.simpson at gmail.com>
> *Cc:* petsc-users <petsc-users at mcs.anl.gov>
> *Sent:* Wednesday, June 24, 2015 5:05 AM
> *Subject:* Re: [petsc-users] jacobians for multicomponent problems
> On Tue, Jun 23, 2015 at 7:52 PM, Gideon Simpson <gideon.simpson at gmail.com>
> wrote:
> Suppose I have a problem for which the field variable has multiple
> components, in this case real and imaginary parts, and I have created a DM
> with two degrees of freedom. When assembling a Jacobian associated with a
> nonlinear problem on this data, is there any data management accounting for
> the different components that makes this “easier?”
> DMDA knows about components so that MatStencil has a .c slot for indices.
> Is that what you mean?
> Thanks,
> Matt
> -gideon
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150624/7220ab3a/attachment.html>
