[petsc-users] About MatView
    Barry Smith
    bsmith at mcs.anl.gov
    Sat Jun 20 00:34:16 CDT 2015
  You need to cut and paste and send the entire error message: "not working" makes it very difficult for us to know what has gone wrong.
Based on the code fragment you sent I guess one of your problems is that the viewer communicator is not the same as the matrix communicator. Since the  matrix is on 16 processors (I am guessing PETSC_COMM_WORLD) the viewer communicator must also be the same (also PETSC_COMM_WORLD).
The simplest code you can do is
> PetscViewerASCIIOpen(PETSC_COMM_WORLD,"stdout",&viewer);
>        MatView(impOP,viewer);
  but you can get a similar effect with the command line option -mat_view and not write any code at all (the less code you have to write the better).
  Barry
> On Jun 19, 2015, at 10:42 PM, Longyin Cui <cuilongyin at gmail.com> wrote:
> Hi dear whoever reads this:
> I have a quick question:
> After matrix assembly, suppouse I have matrix A. Assuming I used 16 processors, if I want each processor to print out their local contents of the A, how do I proceed? (I simply want to know how the matrix is stored from generating to communicating to solving, so I get to display all the time to get better undersdtanding)
> I read the examples, and I tried things like below and sooooo many different codes from examples, it still is not working.
>        PetscViewer viewer;
>        PetscMPIInt my_rank;
>        MPI_Comm_rank(PETSC_COMM_WORLD,&my_rank);
>        PetscPrintf(MPI_COMM_SELF,"[%d] rank\n",my_rank);
>        PetscViewerASCIIOpen(MPI_COMM_SELF,NULL,&viewer);
>        PetscViewerPushFormat(viewer,PETSC_VIEWER_ASCII_INFO);
> Plea......se give me some hints
> Thank you so very much!
> Longyin Cui (or you know me as Eric);
> Student from C.S. division;
> Cell: 7407047169;
> return 0;
