[petsc-users] arkimex rejecting all dt in petsc 3.6.0
    Emil Constantinescu
    emconsta at mcs.anl.gov
    Thu Jun 18 11:24:23 CDT 2015
No, I'm not sure if it should. It belongs to the same category as
"problem_type" == TS_LINEAR / == TS_NONLINEAR.
Emil
On 6/18/15 11:15 AM, Abhyankar, Shrirang G. wrote:
> Can the DAE equation type be supplied via a run-time option?
> Shri
> -----Original Message-----
> From: barry smith <bsmith at mcs.anl.gov>
> Date: Thursday, June 18, 2015 at 11:08 AM
> To: Italo Tasso <italo at tasso.com.br>, "Constantinescu, Emil M."
> <emconsta at mcs.anl.gov>
> Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] arkimex rejecting all dt in petsc 3.6.0
>>   Here is the response from Emil who made the changes to the code
>> If you are solving a DAE then in the new version, we introduced a new
>> flag that distinguishes between ODEs and DAEs leading to different
>> semantics. For DAEs this is needed b/c it may not have consistent initial
>> conditions.
>> If solving DAEs, the user has to set the EquationType appropriately:
>> e.g.,
>> ierr = TSSetEquationType(ts,TS_EQ_DAE_IMPLICIT_INDEX1);CHKERRQ(ierr);
>> This is documented in the doc, but I didn't add it to the changelog (Jed
>> pointed it out to me).
>> Currently it only affects -ts_type arkimex. I'll work with Satish to add
>> it to the changelog.
>> *If that's not the case:* let me know and we can dig deeper.
>> Emil
>>> On Jun 18, 2015, at 5:48 AM, Italo Tasso <italo at tasso.com.br> wrote:
>>> I just upgraded to 3.6.0 and my code stopped working. All dt are
>>> rejected. I used the same configure line, same code, same everything.
>>> With 3.5.4 I get:
>>> 0 TS dt 1e-06 time 0
>>>      0 SNES Function norm 2.549981005316e+05
>>>      1 SNES Function norm 6.107056905987e-03
>>>      2 SNES Function norm 1.483881932064e-10
>>>      3 SNES Function norm 9.122873794272e-11
>>>    Nonlinear solve converged due to CONVERGED_FNORM_ABS iterations 3
>>>      0 SNES Function norm 7.790429171165e+04
>>>      1 SNES Function norm 7.289068747803e-04
>>>      2 SNES Function norm 8.227639633330e-11
>>>    Nonlinear solve converged due to CONVERGED_FNORM_ABS iterations 2
>>>      0 SNES Function norm 1.154356516184e+05
>>>      1 SNES Function norm 2.309925413255e-03
>>>      2 SNES Function norm 6.382141981406e-11
>>>        TSAdapt 'basic': step   0 accepted t=0          + 1.000e-06
>>> wlte=0.000654 family='arkimex' scheme=0:'3' dt=1.000e-05
>>> With 3.6.0 I get:
>>>      1 SNES Function norm 6.107056925316e-03
>>>      2 SNES Function norm 1.519319591792e-10
>>>      3 SNES Function norm 9.070104116945e-11
>>>      1 SNES Function norm 6.942541792651e-04
>>>      2 SNES Function norm 8.458781909516e-11
>>>      1 SNES Function norm 2.287202942961e-03
>>>      2 SNES Function norm 6.585201377573e-11
>>>        TSAdapt 'basic': step   0 rejected t=0          + 1.000e-06 wlte=
>>> 324 family='arkimex' scheme=0:'3' dt=1.311e-07
>>> Any ideas? I attached the full output.
>>> Options I use:
>>> -ts_view -ts_type arkimex -ts_arkimex_fully_implicit -ts_adapt_monitor
>>> -ts_monitor -snes_monitor -snes_converged_reason -ksp_type preonly
>>> -pc_type lu -pc_factor_mat_solver_package mumps -snes_rtol 0 -snes_atol
>>> 1e-10 -snes_stol 0
>>> <petsc354.txt><petsc360.txt>
