[petsc-users] TAO: armijo condition not fulfilled
Andreas Mang andreas at ices.utexas.edu
Thu Jun 11 09:53:16 CDT 2015
Hi guys:
I have a problem with the TAO Armijo line search (petsc-3.5.4). My algorithm works if I use the More & Thuente line search (default). I have numerically checked the gradient of my objective. It’s correct. I am happy to write a small snippet of code and do an easy test if you guys disagree, but from what I’ve seen in the line search code it seems obvious to me that there is a bug. Am I missing something or are you not setting
ls->reason
to
TAOLINESEARCH_SUCCESS
if the Armijo condition is fulfilled (TaoLineSearchApply_Armijo in armijo.c; line 118 - 302)?!
It seems to me that ls->reason is and will remain to be set to
TAOLINESEARCH_CONTINUE_ITERATING
if everything works (i.e. I don’t hit one of the exceptions). Does this make sense? If not I’ll invest the time and put together a simple test case and, if that works, continue to check my code.
/Andreas
