[petsc-users] Setting values of a matrix in a blockwise manner
    Matthew Knepley
    knepley at gmail.com
    Wed Jun 10 10:00:53 CDT 2015
On Wed, Jun 10, 2015 at 9:55 AM, Tim Steinhoff <kandanovian at gmail.com>
wrote:
> Thanks for the quick reply!
> "Yes, however in order to get improved performance, you need type MATBAIJ."
> I considered MatSetType(A,MATAIJ); i.e. the non-block type since
> UMFPACK seems to require the seqaij type according to the summary
> page. So do I have to refrain from using the more amiable block-type
> if I want to make use of UMFPACK?
Yes, I think so. What do you need in UMFPACK?
    Matt
> 2015-06-10 16:45 GMT+02:00 Matthew Knepley <knepley at gmail.com>:
> > On Wed, Jun 10, 2015 at 9:42 AM, Tim Steinhoff <kandanovian at gmail.com>
> > wrote:
> >> Hi all
> >> I want to use Petsc to solve some linear systems via the built-in Krylov
> >> subspace methods as well as by means of UMFPACK.
> >> The considered matrix is block sparse with blocks of size 6x6.
> >> Here is what I came up with after taking a look at some of the examples
> >> MPI_Comm comm;
> >> Mat A;
> >> PetscInt n = 10000; /* dimension of matrix */
> >> comm = PETSC_COMM_SELF;
> >> MatCreate(comm,&A);
> >> MatSetSizes(Amat,n,n,n,n);
> >> MatSetBlockSize(A,6);
> >> MatSetType(A,MATAIJ); /* UMFPACK compatible format due to comm =
> >> PETSC_COMM_SELF */
> >> Questions:
> >> 1.
> >> I work on a single node with 2-8 cores. Hence, comm = PETSC_COMM_SELF; I
> >> guess. Is it correct in this contect to set MatSetSizes(Amat,n,n,n,n);
> with
> >> 4-times n?
> > Yes.
> >> 2.
> >> After the above sequence of commands do I have to use something like
> >>   MatSeqAIJSetPreallocation(A,0,d_nnz); /* d_nnz <-> number of nonzeros
> >> per row */
> >> or is it possible to use
> >>   MatSeqBAIJSetPreallocation(A,6,0,db_nnz); /* db_nnz <-> number of
> block
> >> nonzeros per block row */
> > You should use this if using MATBAIJ.
> >> In any case, is something like
> >>   MatSetValuesBlocked(A,1,idx_r,1,idx_c,myblockvals,INSERT_VALUES);
> >> to fill values of one block into the matrix A ok?
> >   Thanks,
> >     Matt
> >> Regards
> >> Tim
> > What most experimenters take for granted before they begin their
> experiments
> > is infinitely more interesting than any results to which their
> experiments
> > lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150610/198860f5/attachment.html>
