[petsc-users] Petsc Binary Write - Memory
Wed Jun 10 09:12:57 CDT 2015
On Wed, Jun 10, 2015 at 9:04 AM, venkatesh g <venkateshgk.j at gmail.com>
wrote:
> Hi,
> Yes I will try Elemental but there is lots of complex routines and
> functions with long codes in Matlab which goes in the creation of the A and
> B matrices, so re-writing in C will take a long time.
> Even if Matlab takes 128 GB out of 256 GB, and the matrix A to be written
> is around 25 GB, then PetscBinaryWrite.m is using more than 100 GB just to
> run.. This is the problem.
> so is there any other way ?
Don't write it as a sparse matrix. Write it as a dense matrix. This is just
a 4 integer header
MAT_FILE_CLASSID, M, N, nz
and then the data.
https://bitbucket.org/petsc/petsc/src/7fe65498eb3a5a672e8885998851e0d5742e4c1e/src/mat/impls/dense/mpi/mpidense.c?at=master#cl-1571
   Matt
> cheers,
> Venkatesh
> On Wed, Jun 10, 2015 at 7:07 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Jun 10, 2015 at 8:32 AM, venkatesh g <venkateshgk.j at gmail.com>
>> wrote:
>>> The size of the matrix is 84500 x 84500
>>> the no. of non-zero elements is 2.7338e+09
>> This matrix is not sparse, it has 40% fill. You should treat it as dense.
>> For dense matrices of this size,
>> you should consider using Elemental. We have an interface to Elemental in
>> PETSc.
>> I recommend writing the code to create these entries on the fly since it
>> will probably be faster than loading
>> them from disk.
>>   Thanks,
>>     Matt
>>> cheers,
>>> Venkatesh
>>> On Wed, Jun 10, 2015 at 6:35 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>> Whats the size of the matrix? How many non-zeros?
>>>> Satish
>>>> On Wed, 10 Jun 2015, venkatesh g wrote:
>>>> > Hi
>>>> > I am trying to write very large sparse matrices A and B for solving
>>>> > generalized Eigenvalue problem
>>>> > so that I can use SLEPC ex7.c code.
>>>> > I want to read matrices from file according to that code. And I
>>>> generate
>>>> > these matrices from Matlab using PetscBinaryWrite.m
>>>> > However, it exceeds my 256 GB RAM in one of the machines. So I am
>>>> unable to
>>>> > generate these binary matrices.
>>>> > Kindly let me know how to write them efficiently.
>>>> > cheers,
>>>> > Venkatesh
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150610/df46ee0c/attachment.html>
