[petsc-users] Problem Setup / Multiple DAs
Paul Urbanczyk
gomer at stanford.edu
Tue Jun 9 19:25:28 CDT 2015
Hello,
I'm relatively new to PETSc, so please forgive me if this is an obvious
question.
For context, I am working on a single-block, structured, parallel CFD
solver using sixth-order compact Pade schemes.
As I read through the manual and materials, it seems that using a
"distributed array" (DA) would be extremely helpful in this case.
When I set up the DA for solution of the Navier-Stokes equations, it
makes sense to set it up with five degrees of freedom (DoFs) to handle
the five conservation equations.
However, there are a number of other calculations that need to be made
(calculation of non-uniform mesh metrics, for example) that do not
involve five DoFs.
Is there a way to handle varying numbers of DoFs with the same
distributed array, or would it be better to use multiple DAs (one with
five DoFs, one with a single DoF, etc) for different aspects of the problem?
Thanks for any/all advice on this matter!
-Paul
