[petsc-users] Weird behavior for log_summary
    Jed Brown
    jed at jedbrown.org
    Mon Jun  8 13:54:16 CDT 2015
Michele Rosso <mrosso at uci.edu> writes:
> Jed,
> In the petscconf.h I have
> #ifndef PETSC_USE_LOG
> #define PETSC_USE_LOG 1
> #endif
> so I guess that is not the problem.
> I run ex50: I attached the output. It does prints the summary.
> The I guess there is something wrong with my code.
> I call mpi_init before petsc_initialize and then I finalize everything
> with petsc_finalize.
Uh, there is no petsc_finalize (it's spelled PetscFinalize), but
remember that it doesn't finalize MPI unless PetscInitialize called
MPI_Init.
> I do not believe I added any other command that could turn off the
> log_summary output.
Then incrementally figure out what is different between your code and
the example.  Or use a debugger to track down the difference.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150608/be9307f2/attachment.pgp>
